Engine is dead
Old Jul 20, 2010 | 02:50 PM
wesphily's Avatar
Engine is dead
I did a large install and tried to start the car only to have is destroy a starter. After some searching we found coolent in the engine.
Anybody know a good place to get a cheap motor?
Old Jul 20, 2010 | 02:54 PM
chris88z24's Avatar
Take out loan, buy crate engine, go nutz.
csementuh's Avatar
Classifieds on here, local junkyards
Morad Motorparts in Ohio has some decent deals. They also have an eBay store. Usually they will give you a good deal if you call it.
Old Jul 20, 2010 | 03:03 PM
ssyellow's Avatar
This^
Old Jul 20, 2010 | 03:11 PM
wesphily's Avatar
you have a link to this place or a phone number?
Old Jul 20, 2010 | 03:18 PM
ssyellow's Avatar
http://www.moradpartscompany.com/
http://cgi.ebay.com/ebaymotors/Chevy...Q5fAccessories
http://cgi.ebay.com/ebaymotors/Cobal...Q5fAccessories
Ehhh first of all do you have a LSJ?
Old Jul 20, 2010 | 03:23 PM
SunburstSS's Avatar
sorry to hear that try
www.car-part.com for local deals
Old Jul 20, 2010 | 03:28 PM
wesphily's Avatar
ya it is an LSJ ss/sc 2007. Thanks for the quick replies btw!
Old Jul 20, 2010 | 03:35 PM
coopercharge's Avatar
Suck to hear this!
Old Jul 20, 2010 | 03:40 PM
wesphily's Avatar
Ya this has been the worst experience ever. Friend and I installed the following. OTTP Stage 2 kit w/mps, OTTP H/E, Option B, OTTP stage 2 trans mounts. Never even got to ride in it. I assume a hose got connected wrong or something. It tooks us 2 days of cussing then 3 weeks of trial and error till we found the culprit.
Old Jul 20, 2010 | 04:16 PM
csementuh's Avatar
How exactly did you cause a big enough coolant leak to flood the cylinders enough to kill it? Nothing you installed should have been near the coolant. Did you take off the intake manifold or something for a dual pass and mess up the install?
Old Jul 20, 2010 | 05:13 PM
wesphily's Avatar
We don't know yet. The engine is coming out tomorrow. We installed a duall pass but I don't understand what could be leaking.
Old Jul 20, 2010 | 05:16 PM
Fidget's Avatar
www.car-parts.com
Old Jul 21, 2010 | 09:49 AM
csementuh's Avatar
One of the seals on the laminova's or end plate could have started leaking badly and the IC system coolant could have flooded the intake and gotten into the engine. That's the best answer I can think of. Is the level of the coolant in the IC system low?
I believe coolant can damage and weaken the cylinders and stuff... But instead of taking the engine out and doing all that work, why not try to suck all of the coolant out and get the engine running? A teardown is exponentially more work. I'd chance it before I pulled the engine.
Old Jul 21, 2010 | 01:09 PM
HyperMuffin's Avatar
When you install dual pass, don't you need to swap around the laminova's in a differen't order?
Old Jul 21, 2010 | 01:39 PM
Yes you do you need to flip the top 2 around if I remember correctly
Old Jul 21, 2010 | 02:26 PM
csementuh's Avatar
Middle two cores get flipped so the coolant flows properly in top/bottom and out middles.
Old Jul 21, 2010 | 02:38 PM
rnjmur's Avatar
The motor may still be good. I don't think the starter is strong enough to bend a rod, which is why it probably killed the starter. Find out where the coolant is coming from and fix the problem then make sure you flush the engine oil to remove any coolant that may be in it as well as getting the coolant out of the cylinders.
Old Jul 21, 2010 | 02:53 PM
csementuh's Avatar
Exactly! He said in another thread that the starter kept shattering teeth, so it would have broken the starter before it broke the engine. I do believe though that coolant can weaken the sleeves possibly? But yes, I'd pull the intake mani off, suck the coolant out of the cylinders, change oil, clear everything well, and try to turn the engine over... Certainly worth a try!
Old Jul 21, 2010 | 03:24 PM
wesphily's Avatar
If rods aren't bent then we may try to reuse the motor. Can somebody verify the switching of the lamnovas for the dual pass endplate?
Old Jul 21, 2010 | 03:54 PM
rnjmur's Avatar
Typically the top and bottom laminovas have the big openings out and the middle two have the small opening out. If you damaged the seals on the laminova that could cause leaking into the intake manifold as well.
Old Jul 21, 2010 | 04:22 PM
csementuh's Avatar
I verified it on post 17...
If you want the directions goto crateenginedepot.com and they have a PDF of the install from GM posted on the product page.
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
