Engine Pwr Reduced / Bouncing Idle
Old Oct 11, 2012 | 11:32 AM
zzxyyy's Avatar
So I've recently bought a 06 cobalt ss sc
When i bought it, it had a bouncing idle normally between 1k - 1.4k. Sometimes it DOES idle normally though, then might start bouncing again here and there. Sometimes the bounce is so dramatic if i cut it out too fast that it almost stalls, give it a little gas and its fine again. But what causes this?
I was told it was the bigger injectors that may cause the bouncing in the idle
But today i turn on the car and the engine power reduced light was on, brought it to the shop and the code said it was a bad throttle positioning sensor. Would this also cause the bouncing idle?
Anything would help guys thanks, new to the cobalt warld =/
Old Oct 11, 2012 | 11:35 AM
Hockeyman's Avatar
a bad TPS would definitely cause a bouncing idle, as well as a vacuum leak or many other things.
Any codes thrown?
Old Oct 11, 2012 | 11:37 AM
zzxyyy's Avatar
i really should of asked for the code..
he literally said theres only one code and it was the TP sensor
Old Oct 11, 2012 | 11:40 AM
Gelladuga69's Avatar
It might be a dirty ass throttle body. I had the same last year.
Old Oct 11, 2012 | 11:41 AM
zzxyyy's Avatar
Would that cause the engine power reduced too?
umrdyldo's Avatar
Yes clean the throttle body first if it has never been done.
Old Oct 11, 2012 | 11:45 AM
Yes, I had a sticky throttle body from dirt and sensors wouldn't match and would give me engine power reduced.
Did it sitting at a light and freeway.. embarrassing ****. Car sounds like ass under EPR and will barely move.
I cleaned the throttle body real good and problem went away.
Old Oct 11, 2012 | 12:15 PM
zzxyyy's Avatar
I'll be honest, I'm not even sure where the throttle body is I've never had to clean one, as well as the TP sensor, don't be harsh but will someone point them out for me?
Old Oct 11, 2012 | 12:17 PM
jonathan923's Avatar
cleaning it might not solve the problem since they tend to go bad most of the times so if thats the case just buy a new one. they go for $95 and its right between your intake and supercharger
Old Oct 11, 2012 | 12:38 PM
zzxyyy's Avatar
What about the tp sensor
Old Oct 11, 2012 | 12:41 PM
throttle position sensor which is the samething as the throttlebody
Old Oct 11, 2012 | 12:46 PM
cobaltsssc760's Avatar
I had same problem but mine happended after i cleaned my tb. Replaced it with a new one and the car runs ****. Just replace tb.
Old Oct 11, 2012 | 01:15 PM
zzxyyy's Avatar
Do I have to buy a certain type? Or will just any tb work, one for the ss sc cobalt of course. It is an aftermarket super charger will that make a difference?
Old Oct 11, 2012 | 01:29 PM
here:
GM ACDelco - New LSJ Throttle Body #
theres other places that have it for cheaper. but thats the one you need. i remember i got one off a site that sells them for $95 new but lost the link to it
Old Oct 11, 2012 | 01:31 PM
1AJeremyD's Avatar
Where abouts in NH are ya? I can lend a hand if needs be. Im down in Nashua.
Old Oct 11, 2012 | 01:41 PM
zzxyyy's Avatar
I'm right in Salem, meeting up with someone who knows a lot will help
Old Oct 11, 2012 | 01:54 PM
1AJeremyD's Avatar
You have a new PM
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
