engine ticking?
engine ticking?
I have this problem I got a whole new timing kit done at a dealership for timching chain knocking they replaced a whole new head as well when I got it back it was good for about 3 weeks now theirs a bit of a light knock forme the middle of the the block and towards the chain again .
help?
help?
Yess it's a light ticking but sounds more as the rpm go up
it's an 06 with 87k on it
Really?
It's a street buy
Really?
It's a street buy
Sounds like an exhaust leak to me.
Check the exhaust manifold bolts and downpipe bolts.
Since they replaced the head, I'm willing to bet they didnt re torque the bolts after a heat cycle.
It sounds like it's coming from my valves the middle of the block and towards the guide bolt on the side of the block
Why not check and see before making a potential easy fix worse.
This way, you will know for sure if you need to pull the cam cover and check the chain & guides.
Start up: http://youtu.be/9PxSEqu1FXk
This my engine start up I just bought a tensioner from zzp hoping it was that made a difference
please help!
please help!
Can I get a list of things that could possibly be wrong gonna take of the the valve cover tomorrow put a new timing tensioner in and out new oil anything I should be looking for??
exhaust leak
loose chain guide
tensioner
check all the followers as well.
would a not tighten guidance bolt be the cause of it??
patooyee
Oct 1, 2015 01:07 PM
