engine ticking?
Old Feb 2, 2015 | 06:48 PM
ernnyyes's Avatar
engine ticking?
I have this problem I got a whole new timing kit done at a dealership for timching chain knocking they replaced a whole new head as well when I got it back it was good for about 3 weeks now theirs a bit of a light knock forme the middle of the the block and towards the chain again .
help?
Old Feb 2, 2015 | 06:52 PM
Supercharged06SS's Avatar
Details? Does it do it at idle?
Old Feb 2, 2015 | 07:03 PM
ernnyyes's Avatar
Yess it's a light ticking but sounds more as the rpm go up
it's an 06 with 87k on it
Old Feb 2, 2015 | 07:09 PM
blueLNFftw's Avatar
Take It back.
Old Feb 2, 2015 | 07:11 PM
ernnyyes's Avatar
Really?
It's a street buy
Old Feb 2, 2015 | 07:23 PM
blueLNFftw's Avatar
To the dealer that did the chain numb nuts.
Old Feb 2, 2015 | 08:00 PM
ernnyyes's Avatar
It was done on no warrantee
Old Feb 2, 2015 | 11:02 PM
Post a vid of the sound
Old Feb 3, 2015 | 07:59 AM
blueLNFftw's Avatar
If the GM dealer did it there almost certainly is.
Old Feb 3, 2015 | 08:59 AM
jcobaltss's Avatar
Possible injector tick?
Old Feb 3, 2015 | 09:30 AM
Staged07SS's Avatar
Administrator
Administrator
Sounds like an exhaust leak to me.
Check the exhaust manifold bolts and downpipe bolts.
Since they replaced the head, I'm willing to bet they didnt re torque the bolts after a heat cycle.
Old Feb 3, 2015 | 03:29 PM
ernnyyes's Avatar
It sounds like it's coming from my valves the middle of the block and towards the guide bolt on the side of the block
Old Feb 3, 2015 | 10:46 PM
mrbelvedere's Avatar
check the accesory chain and tensioner
Old Feb 3, 2015 | 11:53 PM
ernnyyes's Avatar
I'll post a video tomarrow morning it comes and goes and it's more of a ticket and you hear it more when the rpms go up
Old Feb 4, 2015 | 07:15 AM
Staged07SS's Avatar
Administrator
Administrator
You would be surprised how sound can travel in an engine bay.
Why not check and see before making a potential easy fix worse.
This way, you will know for sure if you need to pull the cam cover and check the chain & guides.
Old Feb 4, 2015 | 05:52 PM
ernnyyes's Avatar
Start up: http://youtu.be/9PxSEqu1FXk
This my engine start up I just bought a tensioner from zzp hoping it was that made a difference
please help!
Old Feb 4, 2015 | 05:53 PM
ernnyyes's Avatar
Lsjknockingej:
http://youtu.be/45axhXOgeWA
this is how it sounds with rising rpms
Old Feb 4, 2015 | 05:56 PM
ernnyyes's Avatar
yes ? no?
I wanna do a motor flush and and new oil with a Lucas oil additive for imports and a other oil rocker arms and cams lubercater ???
Old Feb 5, 2015 | 07:13 AM
Staged07SS's Avatar
Administrator
Administrator
You dont need to be using oil additives.
Old Feb 5, 2015 | 06:03 PM
ernnyyes's Avatar
Can I get a list of things that could possibly be wrong gonna take of the the valve cover tomorrow put a new timing tensioner in and out new oil anything I should be looking for??
Old Feb 5, 2015 | 10:47 PM
chris88z24's Avatar
That would be too easy for him.
Old Feb 6, 2015 | 07:07 AM
Staged07SS's Avatar
Administrator
Administrator
dont just change a part until u know for sure its the part causing the issue, but to answer your question....
exhaust leak
loose chain guide
tensioner
check all the followers as well.
Old Feb 9, 2015 | 08:20 PM
ernnyyes's Avatar
exhaust leak
loose chain guide
tensioner
Well I checked everything and it still does it put new oil new filter New tensioner and that knocking is still their but not at idle only when my rpms go up in 1st 2nd & 3rd gear
would a not tighten guidance bolt be the cause of it??
Old Feb 9, 2015 | 09:42 PM
chris88z24's Avatar
Probably the supercharger coupler.
HEATON
Oct 16, 2015 07:21 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
