evap moniter not ready
Old Feb 1, 2007 | 05:47 PM
JapEatr's Avatar
South Central *********
i got a po103 code after a few hard runs
i cleared it and have since put a few drive cycles on the odo but still evap is my only IM moniter that is not ready still, hmmm could be an issue
any ideas
Old Feb 1, 2007 | 05:58 PM
Witt's Avatar
Some take just the right conditions to go ready. I can look that one up in a few.
OK here goes:
  1. Three or more drive cycles with a minimum of 17 hours between cycles
  2. The difference between the startup engine coolant temperature (ECT) and the startup intake air temperature (IAT) is less than 8 degrees C (14.4F)
  3. The barometric pressure (BARO) is more than 74 kPa
  4. The startup ECT is between 4-30 degrees C (39-86F)
  5. The startup IAT is between 4-30 degrees C (39-86F)
  6. The fuel level is between 15-85 percent
  7. The battery voltage is between 10-18 volts
  8. The estimated ambient tmeperature at the end of this drive cycle is between 2-32 degrees C (36-89F)
  9. The shutdown ECT is 70 degrees C (158F) or higher
  10. A refueling event is not detected
Those are the conditions necessary for the I/M to set ready assuming the vehicle passes the EVAP tests of course.
Old Feb 1, 2007 | 07:29 PM
JapEatr's Avatar
the difference in ECT and IAT certanly applies
i need to test my battery
and 17 hours has deffinatly been accomplished
a refueling event and fuel level...im at like 60 % fuel level and havent got gas since then
ill keep checking with my scanner as im doing my datalogging
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
