Extremely confused. Any ideas?
I have an 09 LNF with;
ZZP Uppercharge Pipe
ZZP Short Ram Intake
ZZP Catless Downpipe
ZZP ZFR 6758
HAHN Intercooler
GMS1 3 Bar Map Sensors
Tuned with HPTuners.
I'm running a 25psi tune that was working perfectly. Last week I changed my clutch out and put the GMPP LSJ Kit in with a new LSJ Flywheel. Now, for some unknown reason that makes absolutely no sense to me, I'm not boosting properly. I normally hit 25-27psi at WOT but now, I hit 15 from 3krpm-5krpm, after 5krpm it climbs from 15-25 as the rpms go through 5k-6.8k. I disconnected the ECM, the entire Underhood Fuse Block, Back Up Lamp Sensor, 2nd O2 sensor connector on the DP and everything else was suspension, cradle and the trans itself. We checked the tune and it's still commanding what it's supposed to but I can't boost worth a damn and can't seem to figure out why.
No DTC's and according to the Tech 2 at work, and HPTuners, my car is running like it should, so I have nothing to go on at the moment. I double checked all of my connections, hoses, fuses, ecm connectors, everything. I'm at a loss.
ZZP ZFR 6758
HAHN Intercooler
Smoke tested directly into the intake and into the intake manifold today. No leaks anywhere.
Readjusted the Wastegate Actuator as well.
Same thing. I did notice I have a weird rumble that sounds like it's coming from the exhaust when I rev to 3500rpm as the revs come back down. It rumbles for a split second then disappears. Maybe the resonator?
Ran another boost leak test just to be sure and came up with nothing. Seems like no one on the planet has any idea what's going on.
I'm going to disregard the clutch installation and say it's a coincidence. It's like the turbo can't spool fully until 5krpm.
I ran a smoke test and there's no vacuum/boost leaks. Checked both Map Sensors and they're fine as well. Only thing I haven't tested is the W/G and the Solenoid on the Turbo. The MAF is reading correctly too.
https://www.cobaltss.net/forums/show...631&styleid=10
Finally found it
Yeah I would start looking at the wg rod and the actuator solenoid
Finally found it
