Fluids
Old Aug 10, 2008 | 02:28 PM
OrangeCrush's Avatar
Fluids
Does anyone know what type of fluid in in the small reservoir in front of the SC? It's getting low and i'm not sure what to fill it with. I have heard that it's just coolant or 50/50?
Can anyone help i'm going on a road trip in a couple of days.
Old Aug 10, 2008 | 03:13 PM
O2br2's Avatar
I am pretty sure it is a 50/50 mix or the same mix you would use in your engines coolant system. It is in the owners manual somewhere. And I think it says to fill it up to the level where the neck meets the coolant lines. My level fluctuates. Sometimes it is about level with the neck and other times it is up the neck an inch or so.
Old Aug 10, 2008 | 03:15 PM
cool thanks bro
Old Aug 10, 2008 | 03:17 PM
M-Dub's Avatar
Yes it is a 50/50 dexcool water mix for your heat exchanger.....
It's supposed to be low like that, there is a line at the very bottom of the neck... don't fill it past that line!
Old Aug 10, 2008 | 03:27 PM
O2br2's Avatar
If you are going to add a little think about using Redline Water Wetter. Follow the instructions and only use what it says to use and it will make your intercooler laminovas a little more efficient at removing heat from the compressed air in your intake. It probably doesn't make a big difference but anything is better than nothing. A full bottle of Water Wetter will treat the engine coolant and the intercooler coolant if you measure it according to the instructions and it will not hurt anything.
Old Aug 10, 2008 | 03:29 PM
So...I shouldn't use coolant/anti-freeze mixture?
Old Aug 10, 2008 | 03:32 PM
M-Dub's Avatar
Coolant and Anti-freeze are the same thing! Use DEXCOOL 50/50 its already mixed for you!
Or just use Water Wetter to fill it to the line!
Old Aug 10, 2008 | 03:35 PM
O2br2's Avatar
No, use the DEXCOOL mix if you want to. Water Wetter just makes the DEXCOOL a little more efficient at removing heat. If your coolant is level with the bottom of the neck it is fine. Don't overfill it to much. A 50/50 mix is fine. I siphoned some coolant out of mine and replaced it with Water Wetter according to the instructions on the bottle but don't overfill it.
Old Aug 10, 2008 | 03:41 PM
yeah i bought the dexcool 50/50, thats what i meant with the mixture...thanks for the help guys.
Old Aug 10, 2008 | 03:42 PM
M-Dub's Avatar
How do you know it is low? I am trying to figure that out?
Old Aug 10, 2008 | 04:10 PM
the line shows it's low
Old Aug 10, 2008 | 08:46 PM
theneelster's Avatar
Wouldn't that mean the main coolant tank is low? It's just an indicator tank.
Old Aug 10, 2008 | 10:56 PM
rukkee's Avatar
The engine and intercooler are different systems . The intercooler filler neck has a cold line on it that is pretty far down the neck. Dont overfill it as it needs room for expansion
DarrenGC
Dec 24, 2021 01:55 PM
Tupp
Sep 29, 2015 11:07 PM
Cptnslo
Sep 24, 2015 09:32 AM
Sean Cummings
Sep 11, 2015 09:35 PM
chris88z24
Sep 8, 2015 01:55 PM
