Fuel Pressure problem
Old Aug 31, 2012 | 02:26 PM
DPaul6590's Avatar
So, after 3 months, I have finally got the car back together.
Problem is it is throwing a P0087 code (fuel pressure too low). I have read and read and every says it is the HPFP failing, so I replaced that. No change. I clear the code and it pops back up within 5 seconds.
Other things point to it possibly being the fuel rail itself but I would like some input before I drop the cash on one of those. There is a loud ticking when the car is running coming from the fuel pump area. I know the car does that some, but this is a little louder and more continuous than I remember it being. I will try to get a video of it to post up.
Any input will help so that I don't waste my money changing stuff that doesn't need to be changed.
Thanks.
Old Aug 31, 2012 | 02:45 PM
Frogstofall's Avatar
Did you replace the hpfp lines? Did you check the fuel rail sensor?
Old Aug 31, 2012 | 02:50 PM
DPaul6590's Avatar
Which lines need to be replaced?
And how would I go about checking the sensor? I'm pretty new to the fuel system area.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
