G-dang Flipin Belt Squeek!!!!!!!
i'm gonna loose it here.....i cant handle this dam noise any more...i swaped out my SC pully for a 2.9 BilletFlow pulley....than i swaped out the idler pully for a bigger one to make up the slack differance.....and the belt STILL squeeks untill the car is worm...>WHY!!!!!!!!!!!!!!!!!!!!!!
the only reason i can kinda think of is....its squeek has somthing to do with the HUGE amount of belt dressing on the belt and other pullys that i sprayed on before i swaped out the idler pulley....any ideas????...why does it stop once the car gets worm?
you sound like my little nephew, always bitching. how's the tranny coming btw?
Originally Posted by sneaky
the spluge is gone from the pulleys at this point. just think warm thoughts
you sound like my little nephew, always bitching. how's the tranny coming btw? sneaky....i'm killing you in your sleep damit!!! always pickin on my Ass!!! how about next time you dont talk unless you can help!!!
jk bro
....your a joke....
jk bro
jk bro
want my advice? go back to stock. hope this helps.
Warm Regards,
Mike
P.S Maybe the squeek is coming from your vagina.
P.S Part 2 - Go to a smaller idler pulley and run a 3.1 pulley setup instead w/good year gator belt. Will be a lot better
Warm Regards,
Mike
Warm Regards,
Mike
and umm mike check your vagina cuz your so full of **** it must be leakin outta you there....**** STAIN!
and no i'm not gonna swich to a 3.1 pulley...my 2.9 is far better!
punk!
STOCK MY ASS!!!!!
punk!
punk!
The nittos come on in the spring, your going to get owned@
were going to have to race down university or squirrel once I get my car out :P
ahahhaha you think you got what it takes to hang with me son????
**** your mod list isnt half of mine....work on that car of yours than we'll talk....
gonna learn the hard way arnt ya
Originally Posted by NGalaxyTimmyo
You'll have to let me know when you get a solution. I wasn't thinking about going smaller then 3.1, but I might now. Can't wait for spring now.... and the next meet.
, mods don't mean **** if you can't put the power down fool :P
if you drive like my mom does then I have no problem beating you
, mods don't mean **** if you can't put the power down fool :Pcuz once i get my clutch to hook due to my masive power increase over you thats all your gonna be able to think about....ARE YOU CHALLENGING ME!!
p.s. back to the reason of this post does ANY body have any idea why the belt still squeeks?
**** the only thing you have to worry about here is...Do you like the smell of burnt clutch????
I get my car on March 1st. After my tires are installed you want to run? You can meet me at discount tire biatch.
Mine squeeks also. I only have a 3.15 sooo... My thought is maybe it is because it is an aluminum pulley so once it gets warm it expands ever sooooo and then the squeak goes away ? I would like to see if it squeaks on startup in the warmer months. In other news my car is running like **** and the dealer wont do anything about it until I take my tq brace off. I am buying NGK copper plugs as we speak to get a range colder. Maybe it is engine knock that I am hearing but I doubt it only running a 3.15.
Originally Posted by 1stbluSS
BTW If you are at the michigan meet I would like to run you. Just to see if our cars are comparable. With the mods we have done. By then hopefully I will have stg2
yea i'll do some comparison with you if you want...if stg 2 is out by then i'll have the reflash and injecters...all i need
also i think it'll be nice to see if it squeeks once its worm as well.....only time will tell i guess
The michigan meet that I am organizing. See my post called Michigan Meet in general discussion there is all the detail I have about it to this point in the thread.
COME ON SMART PEOPLE!!!!! somebody has to kno why this dam thing is squeekin!
Belt dressing? Why did you put that on and does it keep the belt wet looking all the time? Belts are rubber and like all rubber once it is warm it softer allowing it to go further into the groves and it gets better traction just like you tires. Did you have any oil on your belts or anything slick? If you did you need to take the belt off and get all oil off and you problem should be fixed.
It isn't oil. The guys that made the pulley put it on for me so I know everything went right. Plus I was there. I stand firm in my theory that it is because the pulley is aluminum and the weather has been changing from 20* - 50* every day around here. Thus causing expansion and contraction so once warm it expands and the belt catches the grooves better. THANK YOU BILL NYE !
this is a first!!!!!!!!!
I'm challanging you
I get my car on March 1st. After my tires are installed you want to run? You can meet me at discount tire biatch.Thread
