G-dang Flipin Belt Squeek!!!!!!!
Old Jan 30, 2006 | 12:47 AM
06black's Avatar
i'm gonna loose it here.....i cant handle this dam noise any more...i swaped out my SC pully for a 2.9 BilletFlow pulley....than i swaped out the idler pully for a bigger one to make up the slack differance.....and the belt STILL squeeks untill the car is worm...>WHY!!!!!!!!!!!!!!!!!!!!!!
the only reason i can kinda think of is....its squeek has somthing to do with the HUGE amount of belt dressing on the belt and other pullys that i sprayed on before i swaped out the idler pulley....any ideas????...why does it stop once the car gets worm?
Old Jan 30, 2006 | 12:50 AM
3fo893013L's Avatar
the spluge is gone from the pulleys at this point. just think warm thoughts you sound like my little nephew, always bitching. how's the tranny coming btw?
Old Jan 30, 2006 | 12:52 AM
06black's Avatar
sneaky....i'm killing you in your sleep damit!!! always pickin on my Ass!!! how about next time you dont talk unless you can help!!! ....your a joke....
jk bro
Old Jan 30, 2006 | 12:58 AM
3fo893013L's Avatar
jk bro
want my advice? go back to stock. hope this helps.
Warm Regards,
Mike
P.S Maybe the squeek is coming from your vagina.
P.S Part 2 - Go to a smaller idler pulley and run a 3.1 pulley setup instead w/good year gator belt. Will be a lot better
Old Jan 30, 2006 | 01:08 AM
06black's Avatar
Warm Regards,
Mike
STOCK MY ASS!!!!!
and umm mike check your vagina cuz your so full of **** it must be leakin outta you there....**** STAIN!
and no i'm not gonna swich to a 3.1 pulley...my 2.9 is far better!
punk!
Old Jan 30, 2006 | 01:22 AM
3fo893013L's Avatar
STOCK MY ASS!!!!!
punk!
were going to have to race down university or squirrel once I get my car out :P
The nittos come on in the spring, your going to get owned@
Old Jan 30, 2006 | 02:21 AM
06black's Avatar
ahahhaha you think you got what it takes to hang with me son????
**** your mod list isnt half of mine....work on that car of yours than we'll talk....
gonna learn the hard way arnt ya
Old Jan 30, 2006 | 02:30 AM
NGalaxyTimmyo's Avatar
You'll have to let me know when you get a solution. I wasn't thinking about going smaller then 3.1, but I might now. Can't wait for spring now.... and the next meet.
Old Jan 30, 2006 | 03:38 AM
06black's Avatar
i'll keep ya posted there timmyo...i need some more help from all thouse guys on here that are way better at this stuff than i am tho.....
Old Jan 30, 2006 | 08:14 AM
3fo893013L's Avatar
if you drive like my mom does then I have no problem beating you , mods don't mean **** if you can't put the power down fool :P
Old Jan 30, 2006 | 11:17 AM
06black's Avatar
**** the only thing you have to worry about here is...Do you like the smell of burnt clutch????
cuz once i get my clutch to hook due to my masive power increase over you thats all your gonna be able to think about....ARE YOU CHALLENGING ME!!
p.s. back to the reason of this post does ANY body have any idea why the belt still squeeks?
Old Jan 30, 2006 | 11:19 AM
3fo893013L's Avatar
I'm challanging you I get my car on March 1st. After my tires are installed you want to run? You can meet me at discount tire biatch.
Old Jan 30, 2006 | 11:20 AM
1stbluSS's Avatar
Mine squeeks also. I only have a 3.15 sooo... My thought is maybe it is because it is an aluminum pulley so once it gets warm it expands ever sooooo and then the squeak goes away ? I would like to see if it squeaks on startup in the warmer months. In other news my car is running like **** and the dealer wont do anything about it until I take my tq brace off. I am buying NGK copper plugs as we speak to get a range colder. Maybe it is engine knock that I am hearing but I doubt it only running a 3.15.
Old Jan 30, 2006 | 11:21 AM
1stbluSS's Avatar
BTW If you are at the michigan meet I would like to run you. Just to see if our cars are comparable. With the mods we have done. By then hopefully I will have stg2
Old Jan 30, 2006 | 11:25 AM
06black's Avatar
what MI meet are you talkin about? i'll prob be there any way but still
yea i'll do some comparison with you if you want...if stg 2 is out by then i'll have the reflash and injecters...all i need
also i think it'll be nice to see if it squeeks once its worm as well.....only time will tell i guess
1stbluSS's Avatar
The michigan meet that I am organizing. See my post called Michigan Meet in general discussion there is all the detail I have about it to this point in the thread.
Old Jan 31, 2006 | 02:27 AM
06black's Avatar
alredy got back to you on that one...pm sent
COME ON SMART PEOPLE!!!!! somebody has to kno why this dam thing is squeekin!
Old Jan 31, 2006 | 08:20 AM
3fo893013L's Avatar
This thread is funny. I don't think anyone has an answer for you Bryan. Maybe you overtightend some things. I'd pull it all off and re-examine everything. That's just me though.
Old Jan 31, 2006 | 08:32 AM
Chevypowered's Avatar
Belt dressing? Why did you put that on and does it keep the belt wet looking all the time? Belts are rubber and like all rubber once it is warm it softer allowing it to go further into the groves and it gets better traction just like you tires. Did you have any oil on your belts or anything slick? If you did you need to take the belt off and get all oil off and you problem should be fixed.
Old Jan 31, 2006 | 08:42 AM
1stbluSS's Avatar
It isn't oil. The guys that made the pulley put it on for me so I know everything went right. Plus I was there. I stand firm in my theory that it is because the pulley is aluminum and the weather has been changing from 20* - 50* every day around here. Thus causing expansion and contraction so once warm it expands and the belt catches the grooves better. THANK YOU BILL NYE !
Old Jan 31, 2006 | 09:46 AM
06black's Avatar
i was spraying my belt with belt dressing becasue it does a good job at stoping squeeks on loose belts but now i know its tight and it still squeeks and nobody on here has an answer!!!!!
this is a first!!!!!!!!!
Old Jan 31, 2006 | 09:47 AM
06black's Avatar
i just cant see the aluminum is exspanding that much its an alloy for strength so it schouldent grow or shrink that much
Old Jan 31, 2006 | 09:48 AM
06black's Avatar
**** yea sneak...you call me when you get them tires and its on...DUMB WHITE BOY!
DarrenGC
Dec 24, 2021 01:55 PM
justinchinn
Oct 2, 2015 12:18 PM
cw383
Sep 30, 2015 12:41 AM
grampss
Sep 27, 2015 08:51 PM
bobbob160
Sep 15, 2015 11:31 PM
