Gas mileage sucks
Old Sep 9, 2011 | 08:35 AM
donald's Avatar
Cool Gas mileage sucks
SO WOULD NOT HAVING A TUNE AND A SMALLER UNDERDRIVE PULLEY KILL MY GAS MILEAGE I HAVE FULL EXHAUST K&N TYPHOON ADN SAMLLER UNDERDRIVE PULLEY
Old Sep 9, 2011 | 08:55 AM
Mr.N00bLaR's Avatar
I didn't know you could run the car on different sized injectors with out a tune. lulcaps btw.
Why do you have an underdrive pulley on an ss?
Old Sep 9, 2011 | 09:05 AM
donald's Avatar
its a 2.4 im not sure i need to put the stock one back one they said it would get a bit more power plus it was free with the intake i bought off a guy around town here
Old Sep 9, 2011 | 12:23 PM
sLAsh's Avatar
If you get bigger injectors without tuning you will be running too rcih and probably kill your cat besides getting bad gas milage. Your PCM will comand the same duration for the injector to be open but because they flow more it will put more gas into the cylinder.
Who told you to get bigger injectors anyway? Your stock ones should be fine wtih your current mods.
Old Sep 9, 2011 | 12:28 PM
donald's Avatar
ok he told me the underdrive pulley would call for more fuel so to get my mpgs back to almost stock i would need what? cause 25 mpgs is killing me right now im use to 30to 35
Old Sep 9, 2011 | 12:29 PM
BYT*SS*TURBO's Avatar
No tune with the bigger injectors will def cause it to dump fuel!
Old Sep 9, 2011 | 12:44 PM
donald's Avatar
ok so what is th problem
Old Sep 9, 2011 | 12:46 PM
Whitnith's Avatar
Already been told...
Old Sep 9, 2011 | 12:47 PM
umrdyldo's Avatar
Get a new tune or go back to stock injectors.
donald's Avatar
got that but i dont have bigger injectors yet so could anyone chime in and tell me the problem no injectors just stock ones and when i accelerate i lags a little before it opens up
Old Sep 9, 2011 | 12:55 PM
Whitnith's Avatar
If you don't have bigger injectors, why does your first post even talk about them then?!?
Old Sep 9, 2011 | 12:58 PM
rivaladore's Avatar
So wait let me get this straight. First you say you have bigger injectors and then you say you don't. Well if it's the latter and you say you have worse gas mileage and hesitation I would assume you need a new primary o2 sensor. I would also check the plugs to. Without being able to monitor or log the car that's the best advice I can give you for now
Old Sep 9, 2011 | 01:10 PM
umrdyldo's Avatar
I thought the same thing.
OP, on your next post. Slow down your typing. Use proper english and tell us what is on the car so we can help.
donald's Avatar
ok i was going to get them but i wasn't sure of it and the primary 02 sensor is the one on the header or dp what about the tb had and issue with reving after i cleaned it i guess the plug got some stuff in it and after that it would rev to like 3 grand and stay there let it sit for 2 weeks in the hot ass florida sun and it went back down but at 60 i can hear it flukuagte(not sure ho to spell that) threw the exhaust any suggestions
Old Sep 9, 2011 | 01:17 PM
donald's Avatar
lets see k&n typhoon intake, full 2.5 flowmaster exhaust from cat back duals, and smaller crank/underdrive pulley and use all synthetic fluids and 93 octane gas cause that is what the manual calls for idk y but that is what it says
Old Sep 9, 2011 | 01:30 PM
JL-KA's Avatar
My intake increased my mpg by 2-3. Exhaust should also help. My guess is you're getting on it more to hear the intake and exhaust.
Old Sep 9, 2011 | 01:45 PM
donald's Avatar
na drive like i normally do went to the track to and ran .5 seconds slower than before
before i had the injen cai,and over axle duals and no pulley
Old Sep 9, 2011 | 01:52 PM
donald's Avatar
ok so whats ur mpg now
Old Sep 9, 2011 | 06:19 PM
JL-KA's Avatar
I have a 2.2 not a 2.4 but before my intake I was getting 37. After I managed 40. Same drive, same time of day, same speed.
Now with my wheels it's gone down a good bit.
Old Sep 9, 2011 | 06:24 PM
LS6Rally's Avatar
How many miles? is the filter clean? MAF clean? TB clean? Plugs. check all of the basic stuff first. if there is no chack engine light on there it has to be somthing small. have you had really hot weather lately?
Old Sep 9, 2011 | 08:33 PM
emiller's Avatar
Are your new wheels bigger and heavier than the stock ones?
Old Sep 10, 2011 | 05:36 AM
donald's Avatar
i don't have new wheels they are painted stock wheels and my miles are 101000 and i use to get like 35 now i get 25 where do i find the 02 sensors
Old Sep 10, 2011 | 08:07 AM
emiller's Avatar
My bad. I didn't read the name. It was for jl-ka.
Old Sep 10, 2011 | 12:12 PM
sLAsh's Avatar
I read this 3 times and I'm still not sure if I got everything you are trying to say.
Did you say you cleaned your TB and then had problems with the idle and with the throttle fluctuating? If so that is where I would start. Might be TPS but I would expect that to set a code. Free thing to try is disconnecting the battery for amlittle bit to reset to base setting. If you haven't killed something on the TB by cleaning it improperly this will reset the idle.
If that's not what your problem is maybe someone else will have better luck figuring out what you said in your post
Old Sep 10, 2011 | 12:15 PM
donald's Avatar
ya i guess when i cleaned it i got some carb cleaner in the plug part and it threw a light but now it dosent so idk would you know if it would be a o2 sensor and without a code idk
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
patooyee
Oct 15, 2015 05:11 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
