Help !! Acceleration issue
Old Apr 6, 2012 | 09:31 AM
Dazjr92's Avatar
I have a 07 Chevy cobalt LS with the 2.2 L manual transmission. When I accelerate full throttle the rpm's go up then bog and then slowly catch back up. What can cause this issue?!
Old Apr 6, 2012 | 09:47 AM
willie_panic's Avatar
Does the engine bog while in any gear or after a shift?
Old Apr 6, 2012 | 11:47 AM
insylem's Avatar
When the RPMs go up the first time is the vehical accelerating with it? Or do the RPM get ahead of vehical speed, then bog down as the car accelerates to match up with RPMs?
Old Apr 6, 2012 | 12:45 PM
Dazjr92's Avatar
It doesn't do it in gear but after a shift it does. When I jump on the throttle the rpm's get ahead of the car then it bogs and try's to catch back up. Usually happens when I go from partial throttle to full throttle
Old Apr 6, 2012 | 12:54 PM
might try cleaning your throttle body.
Last edited by willie_panic; Apr 6, 2012 at 01:03 PM. Reason: guess I can't read any more
Old Apr 6, 2012 | 12:58 PM
C_A_D88's Avatar
U really need two of these threads?
Old Apr 6, 2012 | 01:01 PM
Dazjr92's Avatar
2.2 manual with no forced induction no mods besides cutting out the resonator and a can on my exhaust
Old Apr 6, 2012 | 02:45 PM
bluebalt07's Avatar
If the rpms go up then bog and start moving up slowly again, it sounds like it could be the clutch slipping, then grabbing and causing the rpms to bog again. You said it doesn't do it when in gear but after a shift it does. Are you making sure you have the clutch fully released before hitting the gas again?
Old Apr 6, 2012 | 06:14 PM
Dazjr92's Avatar
Yea I don't hit the gas again till I let the cutch out
Old Apr 6, 2012 | 08:25 PM
bluebalt07's Avatar
Just making sure. A good way to test if the clutch is slipping is cruise at a low speed in 5th and floor it and if the rpms spike then it is a clutch issue
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
DocSvensk
Sep 27, 2015 02:24 PM
