help with codes please
Old Sep 27, 2013 | 01:26 PM
05g5's Avatar
p0030
p0135
after doing some research seems like these 2 codes come up a lot together, both 02 sensors?
im not good with this general area of stuff, wiring, codes, all that fun stuff.
so any help from the folks that own these same cars is awsome
stock 05 l61
Old Sep 27, 2013 | 01:55 PM
05g5's Avatar
does it make a difference if :
my car is in the low 20's mpg
and takes 35 + minutes to get to 80 degrees C ( 176 F ), and its not even that cold here yet... but cold enough where i want heat in the mornings.. ( thinking rad flush here )
Old Sep 27, 2013 | 02:14 PM
umrdyldo's Avatar
would appear at first glance that the front 02 sensor is bad. The one in the header.
Old Sep 27, 2013 | 02:49 PM
05g5's Avatar
Yea eh, thats both codes? Like a domino effect kinda deal?
Forgot to add, we looked at fuses and a the wires. All looks ok
Old Sep 27, 2013 | 03:31 PM
umrdyldo's Avatar
Found one other post exactly like yours.
It's a simple job if you have a touch of knowledge.
PB blaster
Oxygen Sensor socket
Spray around 02 sensor bolt, let set to soak in.
Break loose with Oxygen socket
Make sure to unplug the other end of the 02 sensor
Take old out, screen in new and clip the sensor in.
Takes all of 20 minutes. Not sure about price.
Old Sep 27, 2013 | 09:41 PM
05g5's Avatar
Is it normal if
I cleared the codes via that reader thing. And put on a solid 200kms of town driving ( and i dont baby this car ) without the cel comming back on?
Old Sep 27, 2013 | 09:43 PM
YelloEye's Avatar
If it hasn't come back I wouldn't worry about it.
Old Sep 27, 2013 | 11:11 PM
05g5's Avatar
Haha wierd
I was went to find the problem, tinkered around with wires and what not, and it fixed it self?
Everywhere i read said bad wires/sensors connections can throw the code. Appears that was my case... Ill bump this if they come bAck. Tks
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
