HELP! I don't know what else to do!
I have a 2005 SS/SC with 48000 miles.
GM Stage 2 kit with k/n typhoon intake.
GMPP exhaust.
The car just recently started acting up. First gear is completely normal which is the part I dont understand...But once I shift into 2-5 the power isn't there. The boost builds up but the car just bogs at WOT. i don't know what else to do... Iv changed plugs and wires... iv clean the MAF sensor...Replaced 02 sensor. Im at a loss of what to try next... Any ideas??
GMPP exhaust.
And im hitting like 15 psi boost
Definately clogged cat ...well 90 percent sure... And yes its covered... Even if ur out of warranty.. unless ur milleage is over 130k there's no problem... Call ur closest dealer and tell them u believe ur catalyc converter has gone bad
I called them this morning... And since I have a branded title, they said its not covered!
Still having problems... I got a P0443 code now which is the EVAP purge circuit.
It still bogs while under heavy throttle...Boost goes up fine.
I hate having no power.
After I described these symptoms to my mechanic he seems to think its not the cat.
He said he will take a look on Friday.
Do u guys think anything else could be the problem?? Im at a loss for ideas now!
Its great.
