Help! - need info on replacing driver's rear turn signal
Old Aug 25, 2010 | 08:48 PM
dawhit99's Avatar
So I've just discovered that to replace the $5 turn signal bulb it looks like I need to remove the factory sub just to be able to remove the trunk liner and then get access to the bulb/harness.
The problem is that I can't tell what size nut is holding the sub in place. It is going to take a deep socket (which I don't have) so I want to know what size I need before I go out and buy one. Has anyone done this and remember what size the nuts are?
I did a search and couldn't find a how to or anything on replacing this bulb.
Any help is much appreciated.
I have the supercharged coupe.
Old Sep 4, 2010 | 12:44 AM
dawhit99's Avatar
Well, if anyone needs to do this in the future you need a 10 mm deep socket plus an extension. I never thought changing a light bulb would take more than 5 minutes, until I looked in the trunk of my balt. oh well.
Old Sep 7, 2010 | 01:43 AM
06SS ALL DAY's Avatar
are u talking about the side marker? because u dont have to remove the sub to change the bulb...
Old Sep 7, 2010 | 01:44 AM
outtamymind's Avatar
ya removing the sub is not required. just pull back the liner and put your hand in there. might get a few scratches and yes it is tight but still quick
Old Sep 7, 2010 | 02:23 AM
jrzdude's Avatar
Not sure about yours, but mine there are 3 plastic wingnuts holding the tail lights on. You can unscrew those with your hand by reaching into your trunk behind the assembly and the tail light comes right out. Very, very easy. Should take you 2 minutes for both
Old Sep 8, 2010 | 01:09 AM
i think my 7 yr old neice could do it
Old Sep 8, 2010 | 01:16 AM
cmatthewb101's Avatar
But yea, no need to remove the sub.
Old May 2, 2021 | 07:42 PM
Austin Danis's Avatar
Actually I think you do have to remove the sub. Your niece might actually be able to turn this since she can fit her hand in there but I sure can’t haha
Old May 3, 2021 | 02:39 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Classic 11 year bump...
GaryGibblez
Jan 14, 2020 10:35 AM
chefhhr
Oct 26, 2015 10:36 PM
Cptnslo
Sep 24, 2015 09:32 AM
QuickSilver_SS
Sep 17, 2015 05:38 PM
ATOMbomb
Sep 11, 2015 10:48 AM
