Help!!! p01182,P0033, p0068 code and limp mode
Old Jun 29, 2014 | 06:45 PM
carldomino's Avatar
Hey guys, I'm new to the Cobalt SS crowd and recently my SS has been going into limp mode with a CEL shooting P01182, 0068 and 0033 together! All the sensors have been check and replaced except bypass valve solenoid.
Could a bad bypass valve solenoid causing this reduced engine pwr issue? I"m also getting ridiculously poor gas mileage as well along with some sluggish acceleration.
Also spark plugs and air filter has been replaced too.
Any ideas guys?
Old Jun 29, 2014 | 08:14 PM
carldomino's Avatar
Search function was used in case y'all ask!
Old Jun 29, 2014 | 08:15 PM
TStone's Avatar
Why don't you look up what the codes are and tell us
Old Jun 29, 2014 | 10:17 PM
carldomino's Avatar
You know... You can go home with your sarcasm, buddy. The search function didn't help me get the answer I need as it lead me to more doubts about solutions. No need to post something if it's not going to help anyone
Old Jun 29, 2014 | 10:22 PM
gibsonj4's Avatar
What mods on the car?
Old Jun 29, 2014 | 10:23 PM
carldomino's Avatar
Bone stock. No mods
Old Jun 29, 2014 | 11:13 PM
06blackbalt's Avatar
Probably the throttle body
Old Jun 29, 2014 | 11:22 PM
carldomino's Avatar
The throttle body was removed and completely cleaned out. :/
Man this is frustrating
Old Jun 29, 2014 | 11:35 PM
We'll did you move the blade? How many miles? Did you look the codes up? Maybe a bad air leak check the intake.... Stock or aftermarket?
Old Jun 30, 2014 | 04:24 AM
carldomino's Avatar
Throttle body was cleaned thoroughly. As stated before, car is bone stock and I pulled the codes which mentions supercharger inlet press sensor malfunction...I think when my friend cleaned up the throttle body and MAF sensor only the p01182 cel is popping up. Should I check the SCIP? That's the sensor on top of the blower right? Do these sensors go bad easily?
Old Jun 30, 2014 | 06:57 AM
lnhetzner's Avatar
Your thread belongs in the problems/ service/ maitenence section for future reference. If you can at all, how much boost are you pulling? Low numbers could mean bad bypass valve.
Old Jun 30, 2014 | 07:48 AM
carldomino's Avatar
Sorry about posting in the wrong forum. And it seems that boost can pass close to 10psi easily but then limp mode kicks in
Old Jun 30, 2014 | 07:57 AM
carldomino's Avatar
Do you mean bad bypass valve solenoid or the little canister looking valve on the supercharger itself?
Old Jun 30, 2014 | 08:43 AM
LScreaminJ's Avatar
Check the scip sensor and clean it with maf sensor cleaner. I was having the exact same issue and I pulled that out gave it a quick spray then it was good. Very annoying problem though I must say. Good luck!
Old Jun 30, 2014 | 09:27 AM
carldomino's Avatar
I'm going to try cleaning out the SCIP sensor first... And as for the bypass valve?
Old Jun 30, 2014 | 09:32 AM
lnhetzner's Avatar
I meant solenoid my bad but if you can get up to 10psi I would disregard it.
Old Jul 1, 2014 | 10:55 PM
carldomino's Avatar
So I replaced the SCIP but car still going into limp mode... I have a spare bypass valve solenoid. Do I need to replace that too?
Old Sep 15, 2020 | 01:25 PM
Steven Nicolette's Avatar
Any ideas guys?
the engine power loss is probably do to your map. I had the same problem and replaced it. Now the p0068 and the p1182 are gone and runs fine also check your butterfly valve. Some tech rewired my hose and block it. Hope this helps.
Old Sep 15, 2020 | 01:47 PM
This thread is 6 years old, I doubt the member is even active on the site anymore.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
