HELP! There is no oil on the dipstick
so this cobalt uses 6 & a ˝ quarts of Mobil 1 oil?
Is this the same on the 08/09 tc/ss cobalt? 6 quarts?
If YES wholly **** does this little thing take a lot of oil, does the non-SS's take that much oil?
My beretta only uses 4 quarts & fill the oil filter. 5/30 Mobil oil
I haven't checked my manual, do they really say to just use 6 quarts?
Last edited by theneelster; Aug 17, 2008 at 11:51 PM. Reason: Automerged Doublepost
actually it's 6 3/4. I've looked it up on alldata before to prove people wrong. They saod " there is no way a ******* 4 banger takes that much" I once had my oil changed at a dealership and I gave them 7 qt.s and they gace me one back. i was like uh check that again, And it Was low.
I've got a 7.5L Oldsmobile that only takes 5 quarts!
It can happen. My Cavalier ALWAYS took less than what they recommended. If you filled it like you were supposed to, it'd be WAY past full. When I lived at my old apartment, I had no place to do oil changes, so I was stuck with a quick lube place. Even if I told them otherwise, it would ALWAYS come back overfilled.
Yeeeeeeeeeah, except the Wal-Mart near my old place was a) quite a drive and b) closer to public housing projects than legit apartment buildings. It was a scary place to be in the daytime. The cav wasn't anything more than point-a-to-point-b transportation so I was OK with quick lube. I wouldn't dare go that route with a car like my SS.
importkiller
Sep 30, 2015 07:18 PM
