help. Zfr installed now issue
So I logged lambda and misfire on the way home on my intercepter. When my car starts to pop my lambda fluctuates from .84-.94 when it's not poping stays at .86-.87 and I get misfire for every pop in cylinder 2 no misfire in any other cylinder. Soooo injector seal?
im trifecta tuned with a zfr, never had any of these issues.
ALSO, i'm pretty sure my plugs are at stock gap. so.... are you guys saying i should lower it to .028? do you really notice a power difference.
sorry to thread jack. just thought it was interesting.
im pretty sure my engine is fine, it ran 100% till I put in the zfr. I wasn't even making as much power as stock with the first zfr tune I had and it was doing this. I did find a huge boost leak on the lower map sensor that I fixed. car doesn't buck as much or backfire as much as it did before. but still does it. I will keep playing. see what I can do. im having the exact same symptoms the guys in the injector seal fail thread were having when they lost a seal. got a few more things to try then ill go at the injectors. engine health test or taking it apart is something id do when all the easy cheap possibilities I can do myself are laid to rest.
