hid kit install fail help please
I just got my h7 lights and tried installing but didnt turn on did I do it right? Or are they just messed upbi bought them from ultimatehidkits.com
everything looks correct, the only thing that i still scratching my head is that white/black to red/black cables, thats the connectors that came with?
not kinda like this???
check the fuse?
nvm, saw the cables
check the fuse?
nvm, saw the cables
Well they arent stock headlights and they didnt come with red and black they came with white and black but they kit has red and black so I connected red with white and matxhed the blacks
weird,
but like said previously, check relay (disconnect it and connect it), check the fuse.
check for a good contact on the white/black to red/black connection
OK so I'm the only one who saw that he put his power wire to ground? OP that wire with the smaller fuse needs to go to your fuse box. Peel back a bit of the wire loom/tape on that wire with the small fuse, it SHOULD be red. Take off the fuse box lid, take a 10mm socket and remove the + power post on the fuse box. Take that wire with the small fuse on it, and put that on that post. That's your power wire, your hids arent getting any power. You don't put fuses on ground wires. The bigger "fuse" is actually a relay. Your relay has to get wired to a posative power source. Also if your high beams are on, your hids wont come on, with those headlights, they come on separately.
Sep 28, 2015 12:51 PM
