hid kit install fail help please
Old Mar 8, 2013 | 10:11 PM
SSCOBALTSS07's Avatar
I just got my h7 lights and tried installing but didnt turn on did I do it right? Or are they just messed upbi bought them from ultimatehidkits.com
Old Mar 8, 2013 | 10:38 PM
Twoozofjuice's Avatar
Haha gayy
Old Mar 8, 2013 | 10:43 PM
Bass_Waves's Avatar
Holy hell wiring
Old Mar 8, 2013 | 11:08 PM
b00sted06ss's Avatar
My guess is it has something to do with the relay
Old Mar 8, 2013 | 11:23 PM
So u think the relay is bad?
Old Mar 8, 2013 | 11:37 PM
DFZ24's Avatar
everything looks correct, the only thing that i still scratching my head is that white/black to red/black cables, thats the connectors that came with?
not kinda like this???
check the fuse?
nvm, saw the cables
Old Mar 8, 2013 | 11:41 PM
check the fuse?
Well they arent stock headlights and they didnt come with red and black they came with white and black but they kit has red and black so I connected red with white and matxhed the blacks
Old Mar 8, 2013 | 11:44 PM
DFZ24's Avatar
weird,
but like said previously, check relay (disconnect it and connect it), check the fuse.
check for a good contact on the white/black to red/black connection
Old Mar 8, 2013 | 11:47 PM
DFZ24's Avatar
white/black cables are coming out of the h7 bulbs right?
Old Mar 9, 2013 | 01:38 AM
Yupp right
Old Mar 9, 2013 | 01:46 AM
Ok I just bypassed the whole fuse section and connected them to the other side of the balastt and they work so im guessing the fuses are out
Old Mar 9, 2013 | 02:07 AM
TommyP's Avatar
AWD > FWD
OK so I'm the only one who saw that he put his power wire to ground? OP that wire with the smaller fuse needs to go to your fuse box. Peel back a bit of the wire loom/tape on that wire with the small fuse, it SHOULD be red. Take off the fuse box lid, take a 10mm socket and remove the + power post on the fuse box. Take that wire with the small fuse on it, and put that on that post. That's your power wire, your hids arent getting any power. You don't put fuses on ground wires. The bigger "fuse" is actually a relay. Your relay has to get wired to a posative power source. Also if your high beams are on, your hids wont come on, with those headlights, they come on separately.
Old Mar 9, 2013 | 02:41 AM
Lol that would make a lot of sense thanks ill do that tomorrow I thought the video would help
Old Mar 9, 2013 | 04:02 AM
Old Mar 9, 2013 | 04:10 AM
TommyP's Avatar
AWD > FWD
Looks like that was the problem!
Old Mar 9, 2013 | 04:14 AM
Yupp thanks man I appriciate it
dennis69
Oct 20, 2015 04:49 PM
justinchinn
Oct 2, 2015 12:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 28, 2015 12:51 PM
