Higher engine coolant lsj
Old Aug 27, 2013 | 11:41 AM
microgab's Avatar
Hey guys,
I got my stock radiator replaced a couple of months ago. Now the coolant goes higher than what i used to have before (stock is 75 C, now sometimes goes up to 90 C). Iat2 temps are fine and i don't go wot when the temps are that high. Just wondering what it could be. Fans not plugged in by mechanic or most likely air in the cooling system?
Thanks,
Gab
Old Aug 27, 2013 | 11:42 AM
rico's Avatar
Make sure it's fully bled
Old Aug 27, 2013 | 11:43 AM
blueLNFftw's Avatar
turn the AC on high and go see if the fans are running. If not check if they are plugged in. If so, test voltage on the plug.
If the fans work bleed the system of air.
Old Aug 27, 2013 | 01:15 PM
microgab's Avatar
Perfect thanks guys. I'll check with the AC, thats a nice trick!
Looks like I'll have to buy a option b from zzp :P
Old Aug 27, 2013 | 01:18 PM
blueLNFftw's Avatar
Your engine coolant and aftercooler system coolant are two seperate systems. The DIC displays only the temperature of the engine coolant.
Old Aug 27, 2013 | 01:23 PM
southal cobalt's Avatar
90 c is in normal operating temps. 75 is too, but alittle low. You really don't have to worry until you get above 110 or so. Fans kick in full at about 105 or so. And the ic system is completely different. The motor cooling system is already self bled.
You have no issues
Old Aug 27, 2013 | 09:36 PM
microgab's Avatar
Really? Wow thats good news then thanks But why would it have changed from 75 to max 90? The swap of radiator maybe?
brandon04
Oct 21, 2015 07:04 AM
Sep 28, 2015 12:51 PM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
