Higher engine coolant lsj
Hey guys,
I got my stock radiator replaced a couple of months ago. Now the coolant goes higher than what i used to have before (stock is 75 C, now sometimes goes up to 90 C). Iat2 temps are fine and i don't go wot when the temps are that high. Just wondering what it could be. Fans not plugged in by mechanic or most likely air in the cooling system?
Thanks,
Gab
Thanks,
Gab
90 c is in normal operating temps. 75 is too, but alittle low. You really don't have to worry until you get above 110 or so. Fans kick in full at about 105 or so. And the ic system is completely different. The motor cooling system is already self bled.
You have no issues
You have no issues
Sep 28, 2015 12:51 PM
But why would it have changed from 75 to max 90? The swap of radiator maybe?
