how to test maf sensor
i have been trying to fix idle problem on my 07 cobalt ss/sc and it has injin cai and not throwing a code for the maf being bad but i only code it did throw was bank one sensor one but it was bad 02 sensor replaced still idle shitty bouncing rpm and idles surging when at stop light it will go from bout 800rpm to 300rpm then bounce back up enuff to wear lights dim, dose it the worst when heater/defrost is on??? wanting to no how to test maf with a voltmeter tester and the decimals at idle and rev????? THANK YOU
Did you clean the throttle body,
Doing this seems to cure idle problem for alot of guys,but be careful you dont damage anything.
Less is more with the spray,Procedure is to spray the cloth and clean and not spray directly on the throttle body
otherwise you may soak a sensor and they are quite sensitive.
06 cobalt or ion idles high
My Saturn ion redline was idling like **** up and down. The fix.. Replace coolant temp sensor and thermostat and it with fix idle. Parts are around 50 dollars at auto zone or advance.
Same issue here. Coming up to a light or taking it out of gear while moving faster than 10 mph causes mine to jump. Calm down once I'm stopped. Even died on me a few times.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
