How to tighten E-Brake?
Old Mar 24, 2011 | 04:50 PM
jatkins35's Avatar
Tightening the bolt on the e-brake handle inside the car fixed me right up. Thanks for the instructions and pictures!
Old Jul 5, 2011 | 11:19 AM
wRcKLes's Avatar
Im going to need this for tomarrow the little bolt under the e brake handle is not doing a damn thing for me
Old Jul 5, 2011 | 11:20 AM
outtamymind's Avatar
if thats not doing anything for you pull your rear cup holder and see if the T-bracket is straight, if one side is shorter then the other then you have a seized rear caliper on that side.
Old Jul 5, 2011 | 12:19 PM
Alvasin's Avatar
You have to pull out your center console or armrest. There are two cables, one for each rear wheel, with nuts at the end to tighten each you need to tighten both equally.
Unlocked Phones
Old Jul 5, 2011 | 12:28 PM
wRcKLes's Avatar
the T clamp is sitting at an angle so ill have to check that out I can only hope its that easy
Old Jul 5, 2011 | 12:42 PM
^ mines doing the EXACT same thing dude!
when i let the brake down there is still tension on one of the brakes.
i press the brake peddel down before leaving and you can hear a click and the car rolls freely. im guessing im having the beginning symptoms of a stuck caliper.
did the tightening of the ebrake and within days it was loose again. when i go up to smg next time im going to have fred look at it.
Old Jul 5, 2011 | 01:09 PM
its not actually the caliper that's seizing its the ebrake part of it that is seizing, if you go and look at the calipers you'll see the lever part that shows the position of the ebrake, if you manually release them and not engage your ebrake the brakes work fine.
i had to do this temporarly until i was able to get a new caliper for mine. i also recommend both calipers be changed if one is doing, the other will shortly follow
Builttss
Sep 8, 2015 05:34 PM
Shamrock
Nov 30, 2005 08:39 AM
PaulSS
Jul 16, 2005 08:25 PM
