Hp tuners
Yes it is a bitch to get to, If all else fails, try loosening the lower CP hose clamps so you can wiggle it for better access. Proper tools are key though. Should be able to reach it from above.
And no need to spray any cables
I haven't hit anything. I've ran several boost leak tests took it to a mechanic to see if they could fix it told them what wrong with it and everything..And nothing they ran boost leak test also and found nothing. I just don't get it cause when I start the car I have full boost and everything until about 30 seconds then It's like 3 lbs.. Then I shut if off while rolling drop the clutch I get boost again then nothing it's really weird. No holes in fmic no leaks new Maf cleaned map sensors tighted all couplings around all charge pipes. Only thing I have Is a exhaust leak which is by the muffler... I'm stumped.
Well a p0101 is some type of air meter issue. So you know the problem is between the intake all the way to the throttle body. Will need to check every sensor and every connection. mAF, intake, charge pipes, Map sensors, intercooler.
And this is were the codes come in, the more codes you have OP the more we can narrow in on the potential issue. Generally the P0101 points to a boost leak and not an actual MAF sensor issue. If you have a friend near by with a LNF swap out MAF sensors and see what happens, or keep driving around until the codes set again
Which MAP sensors do you have? Stock or the GMS1s?
Also you could have something wrong with the wiring going to the MAF. The MAF could be working perfectly fine but if the signals aren't getting to the computer its going to jack things up.
You can either do that or trace the wiring and see if you can find anything bad. Only thing is dealership is going to hit you with a $100+ "diagnostic fee" ...but they'll tell you what is wrong
