Hp tuners
First place I'd likely start (is a log, but) in your situation would be with to get the correct o-rings on those map sensors. Those blue o-rings are notoriously problematic and prone to leaking on the cobalts. Many many threads discussing this. Report back once the maps are cleaned and correct size o-rings are installed.
These.... O-RING 3 Bar Map Sensor 12626998
Did u check the signal to your maf? I had that issue a few months back ppl clamed boost leak but my rpd said different. I took a volt tester took the maf out turned the key (didnt start the car). Put the volt tester in the 5 holes and the yellow single wire had no connection. So i got a new maf of ebay and bam no more reduced boost.
Yes I did all of that and also took it to a guy I know who is a mechanic cause I couldn't find any leaks and he said there was no boost leaks. He cleaned all the map sensors also and still nothing.
I checked that fuse and it's fine.
If they're working fine Zach probably crimped them correctly, you might throw some di-electric grease in if the ends of the caps can be exposed and then re-shrink wrap them.
I'm sure he did a fine job, but every now and then I'll have some MAP codes, that's why I've been wanting to do this, just in case. 4 years of temperature swings and vibrations and all...
All this time, energy and money you are wasting on MAFs and O-rings, you could just take it to the dealer and have them diagnose it. There is something you are missing. Tunes don't just go bad, you've replaced the MAFs with no change and you said you've check wiring for breaks and what not. Did you put those O-rings in the MAPs?
No I didn't order the O rings. I was just wondering if you think that could be the probably I know the tune doesn't go bad but it was tuned on that Maf so I was just wondering. I have only put $100 into it so far.
From what I understand, when you tune MAF tables, they don't change when you change MAFs. Those tables are stored on the ECM and regardless of how many different MAFs you put in this thing
You're correct, the difference between MAFs should not be significant enough to mess with how the car runs.
