Hp tuners
Old Nov 3, 2014 | 02:29 PM
  #76
Originally Posted by zavi
Alright thanks guys. I guess I should take it to a dealer though. But won't they mess things up cause the car is tuned?...
Taking it to the dealer may or may not fix your issue. Did you get all the codes and list them? I'm sorry if I missed them.
Old Nov 3, 2014 | 02:52 PM
  #77
umrdyldo's Avatar
I'm going to go out on a limb and say a dealer won't do crap.
Reason being, when most members take it into the dealer and they see a P0101 they go directly to intake and MAF. Then they like to give up when they replace all that and it's not fixed.
What will happen is they will replace the intake items, then look for a tune and then tell you to go fly a kite because of your tune.
Old Nov 3, 2014 | 06:52 PM
  #78
zavi's Avatar
I'll list them tomorrow. Think I'm going to take it to zzp this weekend.
Old Nov 14, 2014 | 01:37 PM
  #79
zavi's Avatar
I can't get my lower map sensor off my lower charge pipes and ideas?
Old Nov 14, 2014 | 01:55 PM
  #80
umrdyldo's Avatar
Unbolt the charge pipe from both ends, then pull it down and remove sensor.
Old Nov 15, 2014 | 04:47 PM
  #81
zavi's Avatar
My codes
Old Nov 15, 2014 | 06:28 PM
  #82
tomj77's Avatar
Why buy new oring, don't think I have ever had a lower map oring stop a leak there, just put silicone around the oring, don't get on map sensor area and put it in and let it dry. Works awesome
Old Nov 15, 2014 | 08:32 PM
  #83
09CobaltSS1's Avatar
Or he could simply get the correct sized o-rings and not have his charge pipe gobbed up with rtv. A correctly sized o-ring will always seal and hold better than rtv in a high pressure system regardless anyways.
Old Nov 15, 2014 | 09:24 PM
  #84
tomj77's Avatar
I had correct size oring, all it takes is one scratch inside the port and it leaks. Not rtv, silicon. Not messy at all and comes off easy. Or e6000 sealant. Especially on zzp lower charge pipe, maf relocate leaked no matter what I tried. Till I used the e6000
Old Nov 16, 2014 | 12:09 AM
  #85
I'm not particularly a fan of e6000 in the automotive world due to it's inability to hold up to gasoline very well, so I'd be sort of hesitant to go that route. I do agree with putting a light coating of something like dielectric grease on o-rings for sure though. It helps lubricate the ring a bit for easier installation, it prevents the ring from possibly rolling, and it adds additional sealing. I'd just be pretty hesitant to use something that cures on o-rings like silicone, rtv or e6000.... unless in an absolute pinch.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
riceburner
Mid Central
Oct 5, 2015 09:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
09SSlow
Sep 28, 2015 12:37 AM
OPCrer
Sep 27, 2015 08:11 PM
