Humming Noise
Old Sep 3, 2007 | 06:33 PM
veilside_735's Avatar
Humming Noise
I have searched the forums and still can't find anything.
I have started noticing a humming sound coming from my tires (I think). It sounds kind of like a lifted truck would with big off road tires. I am pretty sure it is coming from the tires, or somewhere in that area since it has nothing to do with engine rpm. It is wheel speed that seems to dictate the volume and frequency of the noise. Not entirely sure when it started, but it's getting really freaking annoying. Anyone have any idea what it might be?
btw, it's an 07 SS with stock 17" Pirellis
Old Oct 25, 2007 | 04:09 AM
1fastcobalt's Avatar
humming problem
I'm having the same problem with cooper zeon tires. Has anyone had this problem and figured out what it is. Please let us know.
Old Oct 25, 2007 | 07:08 AM
steddy2112's Avatar
Let's see.
Road noise, faster you go the noisier they get...I'll with **** BUM COVER for a 1000!
It is the tires, they suck, or it could be that one of the tires is inflated wrong...check your psi, if they are ok...then realize that chevy sold you a car with extremely gay tires...
Old Oct 25, 2007 | 07:47 AM
Coblasts's Avatar
If you rotated the tire recently from right rear to left front switch the two front ones side to side.
Or you could possibly have a wheel bearing going,is the sound specific to one side?
Old Oct 25, 2007 | 06:48 PM
Toyotech's Avatar
do you ever rotate the tires? run your hand along the tires and see if they are razor edged
Old Jan 13, 2008 | 11:29 AM
I finally got mine in for service yesterday. The right rear wheel bearing was shot. Apparently it's somewhat of a common issue. As soon as I mentioned the noise the knew exactly what to look for.
Old Jan 18, 2008 | 01:37 PM
CCBalla10's Avatar
I have a humming noise coming from my car. I only really notice this when i'm going roughly 45-55 mph. It is a constant noise and sounds like its coming from the engine. anyone else?
Old Jan 23, 2008 | 06:30 PM
SLVz06BLKss's Avatar
i have the same problem, and when i took it to the dealer they told me that "we do not know what the problem is but it SEEMS that all cobalts do that so it must be normal".. My noise is constant once i am coasting, be it at 15mph or 70mph. That noise was not there when i bought the car so i know they are giving me the run around.
Old Jan 23, 2008 | 08:48 PM
montecarloman's Avatar
I get that every once and awhile, the noise comes from the chicks head in my lap . Seriously though I have noticed some noise from my car at right around higway speeds, right in the 65 to 75 area on decel. I believe its normal noise coming from either the final drive or fifth gear itself. Excessive road noise is a sign of a bad tire. A good tech will rotate the tires as a diagnostic procedure to see if the location of the noise changes. Typically a hub will either growl, be loose, or both.
Old Jan 23, 2008 | 09:03 PM
BLK SS/SC's Avatar
mine did it for about 3-4 days then stopped its been prob 15000 miles now and no prob
Old Dec 9, 2014 | 08:17 PM
ROADKONE's Avatar
Revival!
Has anyone ever figured out this random frequency like humming that's heard in the car. I can feel it in my feet and when I rest my hand on my parking brake.
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
