IAT2's are all over the place
Old May 25, 2011 | 01:07 PM
M-Dub's Avatar
dual pass is worthless... get the griffin h/e and meth and you have all the cooling you will ever need
Old May 25, 2011 | 01:09 PM
CobaltVenomSS's Avatar
that heat exchanger is 550+$!!
Old May 25, 2011 | 01:13 PM
Staged07SS's Avatar
Administrator
Administrator
Originally Posted by nizzle
If you have the bleeder line hooked up to the top of your stock HE, then you should not have to do anything. You can try just taking the cap off of your option b tank to let the air out if you want, but you should not have to lift it up or anything like that. I had some IC troubles a while ago which had me questioning whether or my IC fluid was flowing or not. So, I repaced some of the lines with clear hot water heater hose so I could see. Just an idea.
The Opt. B setup can still trap air. Trust me.
I've been running Opt. B for 3 years now, and have had it apart many times in order to add different coolant mixes and what not. It will work much faster if you self burp the system. The tank will begin to bleed the system much faster that way.
M-Dub's Avatar
Yes it is.... but WELL worth the money! I've seen it in action... and sub 110* iats without meth are possible
Staged07SS's Avatar
Administrator
Administrator
Yep. No dual pass on my car.
If I ever do anything else to my cooling setup it would def be the Griffin.
Old May 25, 2011 | 01:14 PM
M-Dub's Avatar
Hell all I had on my lsj was the shittastic Cobra H/E and meth and saw a max IAT2 at the track and 3 back to back runs was 115*....
I also changed my fluid out to straight distilled water and water wetter in the summer
Old May 25, 2011 | 01:15 PM
i just dont wanna run meth on the TVS if i get meth injection itll be water injection
Old May 25, 2011 | 05:39 PM
nizzle's Avatar
well if that's the case, how do you suggest doing that?
Old May 25, 2011 | 05:42 PM
nizzle's Avatar
Ive got it all. opt b, dual pass, zzp S3 HE, no meth and no cobra HE tho. I was hot lapping at the track last week and after 5 straight passes I was still holding good around 120*.
Old May 25, 2011 | 06:56 PM
Staged07SS's Avatar
Administrator
Administrator
I already explained how.
Old May 25, 2011 | 06:57 PM
  #36
Staged07SS's Avatar
Administrator
Administrator
You wouldnt need a cobra heat exchanger. You already have a ZZP front mount. Not sure what you were getting at there.
Old May 25, 2011 | 08:11 PM
  #37
ssblackstealth's Avatar
corn gas ftw....
end the end on an lsj air pockets are your #1 enemy!
Old May 26, 2011 | 01:37 AM
  #38
nizzle's Avatar
I meant no GRIFFIN h/e. I wasnt sure if you were saying the Griffin h/e was better than the ZZP. I wasnt getting at anything, I was just stating what my car did at the track.
Old May 26, 2011 | 03:26 AM
  #39
M-Dub's Avatar
Why on earth not? I did a TVS meth tune in Orlando.... 347whp on the 2.9 pulley 25.5* of timing...
Old May 26, 2011 | 10:05 AM
  #40
Staged07SS's Avatar
Administrator
Administrator
Well, the Griffin is better than the ZZP heat exchanger, but that is a whole different topic
Old May 26, 2011 | 10:10 AM
  #41
Staged07SS's Avatar
Administrator
Administrator
Anyways, I would like to post an update....
I spent some time "burping" the Opt. B tank/coolant system yesterday, and everything is back to normal! I even went ahead (for ***** & giggles), and tapped on the pump housing a little. After all the pump is now 4 years old, and prob starting to get clogged up with deposits from the brushes.
My IAT2's stayed around 15-18*F above IAT1's while cruising to work this morning in 83*F heat. Not bad. They also recovered fairly quickly after sitting at some stop lights. I'm happy to have everything back to normal.
Cobaltvenomss: Let me know how you make out.
Old May 26, 2011 | 12:06 PM
  #42
stenguyen1's Avatar
dang seems everyone having problem in the texas humitiy lol bc my car temp is about 170f vince says and i have it all too... dual pass, dual h/e, option b and i cant seem to get it lower. if anyone knows or have ideas i would love to hear it sorry if thread jacking
p.s. im fully built if that matters and 2.2 s/c
Old May 26, 2011 | 02:22 PM
  #43
well i unscrewed my opt b brackets and too the tank and raised it above the engine and u could tell it was working lol...so i leave it like that for about 10 minutes then screw everything back then on my way to work this morning it was GREAT! but right around the end it started getting high again
Old May 26, 2011 | 02:25 PM
  #44
Staged07SS's Avatar
Administrator
Administrator
Might be the pump man....
Give the pump a few taps. It might be sticking. The deposits from the brushes tend to bind the pump up. It will run for a bit then stick. See if that helps.
Old May 26, 2011 | 02:26 PM
  #45
whats a tap?? hit it hard?? or just tap it?? GO HOME BALL!!! lol i had too
Old May 26, 2011 | 02:34 PM
  #46
Staged07SS's Avatar
Administrator
Administrator
Well, I sometimes don't know my own strength, so I always "tap" things haha. I didnt have a rubber mallet on me so I took a block of wood, placed it over the pump bracket, and started gently tapping away. I don't know if my pump was sticking for sure, but figured it wouldnt hurt to free up some of the deposits and crap that tend to bind these pumps up.
Old May 26, 2011 | 02:36 PM
  #47
ill try burping it again... and if that dont work ill just wait till i do dual pass and struts next week
Old May 26, 2011 | 02:40 PM
  #48
corn gas ftw....
i have a rubber mallet kyle! we got this when i move down next week
gunna hang that opt b tank in the air for a good 30min lol zip-tie's ftw
Old May 26, 2011 | 02:42 PM
  #49
Staged07SS's Avatar
Administrator
Administrator
After I burp the tank, I always remove the bleeder line from the opt. b tank to the stock heat exchanger, and let some coolant **** out of the bleeder line reducer. I don't know if it helps, but it is the bleeder area for the stock heat exchanger so it might. This method has always worked for me when trying to "jump start" the opt. b's bleeding process.
Old May 26, 2011 | 05:11 PM
  #50
M-Dub's Avatar
dude just get a new pump from forced performance man... they are like 50 bucks or something like that.
