IC pump question?
Old Sep 24, 2013 | 04:54 PM
justinchinn's Avatar
IC pump question?
just wondering if the IC pump is suppose to engage as soon as the engine is started or if it is temp sensitive like the cooling fans.. tried searching with no results.
Old Sep 24, 2013 | 04:55 PM
Gelladuga69's Avatar
As soon as the engine is started. It's just like a water pump.
Old Sep 24, 2013 | 05:01 PM
thanks.. only asked because i changed my engine oil earlier today and noticed the coolant wan't flowing so i reached under the car to see if i could feel coolant flowing through the line and when i looked back in the engine bay it was flowing. i didn't tap the pump or anything so i wasn't sure.
Old Sep 24, 2013 | 05:02 PM
06cobaltncng's Avatar
if you crank your car, pop the hood, and check for coolant flow, and there is none, something is wrong.
Old Sep 24, 2013 | 05:10 PM
southal cobalt's Avatar
theres a 10 second delay between turning the key and coolant flow, if youre tune file is stock
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
roth
Sep 26, 2015 12:16 PM
