Installed CA Stage 1, new gasket set, ported TB. Car won't run. PLEASE help!
Here's the story. About a month ago I purchased the Cobalt Addiction Stage 1 kit, which comes with a 3.0 pulley, belt, step colder plugs, and a ECU reflash. In the process of doing this, I realized I had a huge gasket leak into my #3 Spark Plug tube. We removed the valve cover and replaced all 4 spark plug tube gaskets, as well as the valve cover gasket. In addition to this, we cleaned(with carb cleaner) and ported the stock throttle body, basically dremeling out some of the material to increase airflow without getting too close to the throttle plate. I've have done a bunch of them this way with great results on other vehicles, including my 450whp SRT-4 with great results. This is the jist of what we have done.
Now, here is what's happening. Immediately after putting everything on, we started the car. It starts right up, but the idle is all over the place, bounces up and down, then stalls within 10 seconds. If you rev it a little, the rpms will go up, but it is super choppy and will bog and stall within a few seconds. The one and only time we were able to drive it, it jerked horribly all over the place and we got the ENGINE POWER REDUCED on the dash.
Here is what I have checked and done, and has made no difference.
-Checked for obvious leaks
-Double checked all sensors and ECU connections
-Removed throttle body again, inspected, and blew some compressed air through it
-Sent ECU back to Cobalt Addiction for another reflash incase the first was messed up. Replaced and had no effect.
What is wrong that the car will not run? We had it flatbedded to our local Chevy dealership for the CASE relearn, but the tech could not get through the procedure without the car stalling out. Any help or input would be greatly appreciated at this point. I am leaning towards replacing the throttle body next, as carb cleaner MAY have found its way into the sensoring inside and damaged it. After that, I do not know which direction to go. The car has been off the road for longer than I can remember and just want the thing running.
I am located in Northern NJ, so if anyone could recommend a shop/forums member that could get this thing running or at least shed some light, I would greatly appreciate it.
Turbo Johnny
Feb 21, 2019 09:41 AM
RedLined
Sep 9, 2015 09:11 PM
NoBalt123
Sep 4, 2015 07:10 AM
