Key gets stuck in the ignition
Old Apr 28, 2009 | 11:48 AM
BuuGieWuuGie's Avatar
What used to only happen every once in a while now happens almost everytime I turn off the car.
The key will not release from the ignition until I take the car back out of park and slam it back into park. It always releases after I do that. But it is getting really annoying. Anyone know how to fix it?
Old Apr 28, 2009 | 10:19 PM
Erod's Avatar
Moderator Alumni
moved.
pls read this
https://www.cobaltss.net/forums/announcement.php?f=68
Old Apr 29, 2009 | 02:32 PM
DaBuzzard's Avatar
Switch on the shifter assembly is bad. Very common problem.
If the key gets stuck again, take the little rubber cover under the ignition lock off (it just pops out), reach your finger in and push the locking pin back, that will allow you to remove the key.
If you still have warranty, it will be covered.
And before someone else says it, this has been covered many many times, search is your friend
Old Apr 29, 2009 | 07:37 PM
ModRob's Avatar
I get that from time to time. Try this how-to. If the switch fails on me I'm going to have to do this. https://www.cobaltss.net/forums/show...ght=automatics
Old Apr 29, 2009 | 07:40 PM
originaladrian's Avatar
has it fail on me twice. both time the dealer just did it.
turbochargedss2012
Sep 20, 2023 12:17 PM
Shanman
ZZ Performance
43
Aug 26, 2016 08:43 PM
satisfied
Oct 19, 2015 12:35 AM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
