Lc1-Innovate Wideband install
Old Aug 28, 2010 | 04:13 PM
Glowbalt's Avatar
Lc1-Wideband install help!
here's the deal..the HOW-TO on this forum is very unhelpful without pics, so that's why I'm doing this. I need help installing my wideband. I will be doing my build next weekend so any help is appreciated. Start from scratch please.
Old Aug 28, 2010 | 04:36 PM
Glowbalt's Avatar
Old Aug 28, 2010 | 10:54 PM
Glowbalt's Avatar
help please
Old Aug 28, 2010 | 11:03 PM
JMHZ2401's Avatar
Follow the directions that came with it? That is what I did. Pretty easy.
Old Aug 28, 2010 | 11:05 PM
Glowbalt's Avatar
It doesn't really help...
Old Aug 28, 2010 | 11:06 PM
juice3's Avatar
sub'd for I will be doing this in the future....
Old Aug 28, 2010 | 11:07 PM
Glowbalt's Avatar
if someone could add pics to the how-to it would really appreciated...
Old Aug 28, 2010 | 11:54 PM
Glowbalt's Avatar
Old Aug 28, 2010 | 11:55 PM
BLAZIN07SS's Avatar
I'm too JDM for you
what do you need help with? its just plugging in a switched power source, ground, running your wire for the sensor and welding a bung in the downpipe for your wideband sensor
Old Aug 28, 2010 | 11:58 PM
Glowbalt's Avatar
well there's about 4 wires coming from the gauge itself..then about 6 more coming from the controller which the sensor is connected to
Old Aug 29, 2010 | 12:05 AM
Jrhdpaintball's Avatar
yea it was a pain in the ass when i did mine... i had an AEM uego and it was super easy... then to my lc-1 it was a headache. i didnt take any pics, but just keep reading the instructions over and take your time.
Old Aug 29, 2010 | 12:07 AM
BLAZIN07SS's Avatar
I'm too JDM for you
red - 12 volt power
blue - heater ground
white - system ground
yellow - analog 1(only for datalogging, tape them up, you don't use them)
brown - analog 2(only for datalogging, tape them up, you don't use them)
green - analog ground(only for datalogging, tape them up, you don't use them)
black - calibration wire(there should be an LED with the kit, you need to connect the LED to this wire)
Old Aug 29, 2010 | 12:12 AM
Glowbalt's Avatar
red - 12 volt power
ok those are from the controller..but there's a seperate thing that connects to the gauge itself with wires coming out...these wires are smaller, and the ones from the controller are like 3 times bigger..do I color connect them together and wire accordingly?
Old Aug 29, 2010 | 12:23 AM
BLAZIN07SS's Avatar
I'm too JDM for you
everything else should be harnessed. i just pulled up the instructions for an LC1 just to be sure and it is very straightforward
Old Aug 29, 2010 | 12:25 AM
is the gauge you are using an LM1?
Old Aug 29, 2010 | 12:27 AM
Glowbalt's Avatar
mines different..from the gauge it has red,black,yellow,white....from the Lambda sensor controller is has red,blue,brown,black,white,yellow...the red and blue from the controller are the thick wires
Old Aug 29, 2010 | 12:47 AM
Glowbalt's Avatar
ok read the manual a couple of times...now in order to reach for a ground which size wire should I use as an extension?
Old Sep 20, 2010 | 05:57 PM
redbalt's Avatar
Hey guys...just trying to plug my lc1 in..question..what's the difference between the heater ground and the system ground...and when I have the unit all plugged in it only reads 7.4 on the gauge...any help would be appreciated. Thanks.
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
n20saturn
Sep 30, 2015 12:26 AM
