Lc1-Innovate Wideband install
Lc1-Wideband install help!
here's the deal..the HOW-TO on this forum is very unhelpful without pics, so that's why I'm doing this. I need help installing my wideband. I will be doing my build next weekend so any help is appreciated. Start from scratch please.
what do you need help with? its just plugging in a switched power source, ground, running your wire for the sensor and welding a bung in the downpipe for your wideband sensor
yea it was a pain in the ass when i did mine... i had an AEM uego and it was super easy... then to my lc-1 it was a headache. i didnt take any pics, but just keep reading the instructions over and take your time.
red - 12 volt power
blue - heater ground
white - system ground
yellow - analog 1(only for datalogging, tape them up, you don't use them)
brown - analog 2(only for datalogging, tape them up, you don't use them)
green - analog ground(only for datalogging, tape them up, you don't use them)
black - calibration wire(there should be an LED with the kit, you need to connect the LED to this wire)
red - 12 volt power
everything else should be harnessed. i just pulled up the instructions for an LC1 just to be sure and it is very straightforward
mines different..from the gauge it has red,black,yellow,white....from the Lambda sensor controller is has red,blue,brown,black,white,yellow...the red and blue from the controller are the thick wires
Hey guys...just trying to plug my lc1 in..question..what's the difference between the heater ground and the system ground...and when I have the unit all plugged in it only reads 7.4 on the gauge...any help would be appreciated. Thanks.
Delta coupe
Sep 30, 2015 08:11 AM
n20saturn
Sep 30, 2015 12:26 AM
