Tire noise or something worse?
Old Sep 19, 2010 | 09:30 PM
TommyP's Avatar
AWD > FWD
Recently, I've been having an almost roaring noise develop over the last thousand or so miles. It's most noticeable at 40mph and over. I took a video that you can sort of hear it in. It kinda sounds like tire noise but I'm not so sure. I've had these tires on since the spring and this has only started recently.
What do you guys think this is? From the tires? Possibly a wheel bearing or something like that? I know for sure that it's coming from the passenger side.
Old Sep 19, 2010 | 09:57 PM
JshLnsctt's Avatar
I had that same sound coming from my car at 45mph+, when I first got a chance I looked and had broken off two lug studs completely. I'm still not sure if the sound caused the studs to break or if I heard the sound because they had broken. I don't hear it anymore now that I have fixed them, but it might be worth while just to make sure everything you can get at is tight with a wrench.
Old Sep 19, 2010 | 10:11 PM
TommyP's Avatar
AWD > FWD
No it's not that. They're tight and all my studs are there. I'm about 99% sure it's a wheel bearing, according to John Powell. Word enough for me.
Old Sep 20, 2010 | 08:41 AM
rogersj's Avatar
sounds like a wheel bearing, jack the car up and check for free play in the wheel
Old Sep 20, 2010 | 06:09 PM
SC_RXSS's Avatar
Dude...I'm searching on the forum today because of the same issue!! I thought it was my tires, so I went and got them balanced and had the same issue. The tread was still good since I got new tires like a month ago.
Old Sep 20, 2010 | 06:13 PM
BlackARCA06's Avatar
Wheel bearing already? how many miles are on your car?
Old Sep 20, 2010 | 08:35 PM
black67's Avatar
Tommy
You say that is coming from your right side? Do you have any lights coming on, like the Traction Control or ESC? Do you have any shake in the wheel?
Mine had the lights, with a very small hum that I could hear with the windows down. They had to replace the right hub assembly due to the wheel bearing and speed sensor. I only had the car for a few months when this happened to me.
It does sound like a wheel bearing going, so I would have them check it one day when you are at work.
At first that sounded like old rumble strips!!
Old Sep 20, 2010 | 08:39 PM
TommyP's Avatar
AWD > FWD
I've got 22k miles on my car. No vibrations or lights on at all, just a really irritating humming noise. It's getting checked out Thursday when I get my new brakes installed.
Old Sep 20, 2010 | 08:41 PM
kxrida2000's Avatar
Ya I was gonna say wheel bearing also
bigdeertz
Nov 17, 2016 09:41 AM
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
