leaking A/C
Old May 31, 2006 | 07:59 PM
90BerettaGTZ's Avatar
leaking A/C
Since the weather around here has been so hot and humid... I have been using my A/C to the full and all the time basically... Well the other day my buddy notices a drop on his foot and was like.. What's that....
Well I turned my attention to the floor.. To see under the passenger side of the dash was leaking water from a vent or whatever (I didn't investigate under the dash enough to say for sure where it's comin from, just looked under)..
Well my A/C is leaking water all over my floor and mat.. There is condisation the dash when using the A/C.. But I am sure that is normal cause it's so cold.. But I know for a fact that water leaking in my car when using the A/C isn't right...
I mean it builts up pretty quick..
Anyone else have this type of problem?
Old May 31, 2006 | 08:01 PM
HackAbuse's Avatar
Sounds pretty normal to me, i'd still have it checked out though
If the air is humid enough, it will condense right inside the car, I have seen air so humid, that when it exited the vents it actually condensed right in mid-air like steam!
Old May 31, 2006 | 08:02 PM
I am not taking around the condensation by the vents...
I am talking about the water dripping under my dash.
Old May 31, 2006 | 08:03 PM
HackAbuse's Avatar
I know what you mean, how much water is it though, like a measure
Old May 31, 2006 | 08:34 PM
RaineMan's Avatar
I think someone else on here had that problem... it was a long time ago.
Old May 31, 2006 | 08:37 PM
Alex47's Avatar
It is just the vapor tube droping the water to the ground. It is fine
Old May 31, 2006 | 08:49 PM
HackAbuse's Avatar
He means inside the car, correct me if i'm wrong
Old May 31, 2006 | 08:55 PM
05stockbalt's Avatar
i noticed the same thing the other night...after a little research i found out there is a tsb on this...i am at work now but i'll post it up later....i've just been too lazy to get to the dealer to have it fixed
Old May 31, 2006 | 08:58 PM
Chevypowered's Avatar
Theres a fix for this, i read about this last summer, just take it to the dealer and they will fix it.
Old May 31, 2006 | 10:26 PM
Doc's Avatar
Doc
there is a TSB for this, when I go to the dealership tomorrow, I'll check on it for you. Although, they can find it at the dealership if you take it in.
Funny you mentioned this, I had water in the driverside wheel-well and we read the TSB and were stumped. I pulled the panels off where the fuse panel is and pulled the carpet back on the driver side and stuck my hand under the pad and there was at least 2 inches of water. Seems that I had a hole in my firewall and it allowed water to collect and drain into the wheel-well. It's being fixed and hopefully will be back tomorrow.
Old Jun 1, 2006 | 08:10 AM
player_1's Avatar
I had my car taken in for this on monday, dealer fixed it up pretty quick
Old Jun 1, 2006 | 01:30 PM
jokieman's Avatar
Not sure if it's the same thing but we had this happen in our Dodge pickup, The drain pipe for the A/C was clogged and it leaked out water all over the passenger side (in the cabin). they unclogged the drain and it was fine after that.
Old Jun 1, 2006 | 01:47 PM
3fo893013L's Avatar
I had that problem, I originally posted it a long while ago. here is what my car has been doing so far. A complete list of what has happened since I got the car. I brought my car in for the evap screen. It wasn't installed on any cobalt's per GM because it wasn't necessary or they thought anyways
Here is what my car has been brought in for service or problems on an excel spreadsheet.
Purchase Date 03/28/05 Problem Tracker - 05 Chevy Cobalt SS
Problem/Service Done Date Resolution to Problem
Recall on Exhaust March 28th 05' Exhaust from Catback Replaced
Oil Change May 05' Oil Changed
Oil Change/Car Stratched on Both Sides June 05' Oil Changed/Car buffed to remote stratches
Door Handle Sticks June 05' Lubed Door Handle
Air Conditioner spits water out July 05' Installed Evap Screen where one was not on
Oil Change July 05' Changed Oil
Sunroof Trim falls off suddenly July 05' They re-installed trim and fitted button
Air Conditioner spits water out(2nd Request) August 05' Tried to duplicate problem, could not do it
Supercharger Mount Broken for Coolant Lines August 05' Part on order, should arrive second week of August.
Shift patterns on shift knob breaks August 05' Part on order, should arrive second week of August.
Valance needed replacement (user error on purchaser end) August 05' Replacement ordered, should arrive second week of August
Door Handle Sticks(2nd Request) August 05' Doors Lubed
Oil Change August 05' Oil Changed
Battery Light Came On August 05' No Resolution
Oil Change November 05' Changed Oil
Door Sills need to be replaced (Paint Flaking) March 06' New Door Sills will be ordered
Car overheated and went into limp mode March 06' Computer Reflash update to thermostat/fix the overheating, nothing wrong with Cat
Radio Buttons/Cruise Doesn't work on Steering Wheel March 06' Button assembly replacement needed (NO ETA on Fix).
Rotors Warped March 06' Dealership says they can be resurfaced, I am allowing them to resurface them.
Brake Pads Seem Worn March 06' They went down to 10% life, advised them to replace after getting cost to replace
Trim around Dash peeling off March 06' Replacments ordered, they are fixing the door panels and radio buttons on same visit.
Door Handles sticking (3rd Request) March 06' Lubed Door Handles
Seat Belt Loose/Seems broken/Fitment issue April 06' Order replacement belt for Drivers Side. Should replace soon.
Radio doesn't spit out CD's upon eject button pushed May 06' Nothing has been done yet.
Old Jun 1, 2006 | 01:56 PM
3fo893013L's Avatar
By the way, here is my original thread from last year that explains the fix your issue. Enjoy!
https://www.cobaltss.net/forums/show...ighlight=a%2Fc
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
n20saturn
Sep 30, 2015 12:26 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
