Leaks and snoring sounds on exhaust
if your running that rich to were gas is dripping out of your exhaust, you would be the bill gates of air fuel ratios.
no clue what would be the problem other than a tune maybe?
Anyone knows how to check the fuel system is working ok? I thinking also that its the octane of the gasoline here. I dont know how much is it but maybe isn't burning completely inside the engine.
If I reset my car, taking of the battery and leaving the key on RUN for 15min. Will it help? I've heard that this helps to almost every imported car from the US to Bolivia because of the sea level, oxigen flow is not the same as in the states. Weather conditions are very different. Reseting my car will make adjust to fit my weather condition? So, this would stop pumping gas out of my exhaust and the snoring?
sounds like you have an intake side leak it says stage 3 so i assume your st3. check your gaskets and make sure all your bolts on the intake manifold are on right. intake leak will cause misfires etc etc. can't tell too well from the vid but thats what it sounds like to me.
Intake is kinda dirty, I'm cleaning it right now with moist paper towel. I will put it on tight and make sure there are no leaks of air, when engine starts... Any other ideas?
sounds to me like you have 60 lb injectors, get a tuner to look at your car and adjust it for the current area your in.. resetting the car by unhooking the battery might help.. i'm that is more then likely not gas
DANRICKARD
Oct 1, 2015 12:08 AM
