Leaks and snoring sounds on exhaust
Old Oct 22, 2010 | 11:32 AM
chrisjaldin's Avatar
There are some gas leaks, I think, coming out of my exhaust .. Also there is a weird sound as if the was snoring.. Here is a video
How do I solve it?
Old Oct 22, 2010 | 12:11 PM
can't see the video or what?
Old Oct 22, 2010 | 12:28 PM
jonathan923's Avatar
cant really tell. from the vid sounds like ur muffler or exhaust is loose or something and it hits something under the car, IMO
Old Oct 22, 2010 | 02:27 PM
It's coming out gasoline from the exhaust.. :S... it isn't combusting well on the engine, I think.
Might the sparks plugs burned?... What else should I check?
Old Oct 22, 2010 | 02:42 PM
so it seems the car is running very rich. should check with ur tuner or something...and yea i would suggest also take at look at ur plugs.
Old Oct 22, 2010 | 08:28 PM
Any other suggestion?
Old Oct 23, 2010 | 01:36 AM
I want to prepare my car for nationals drag races and I can´t go like that. Please help me out here
Old Oct 23, 2010 | 01:44 AM
ecot3c inside's Avatar
if your running that rich to were gas is dripping out of your exhaust, you would be the bill gates of air fuel ratios. no clue what would be the problem other than a tune maybe?
Old Oct 23, 2010 | 02:49 PM
Anyone experiencing the same problem? Spark plugs? Octane gasoline?...I check the fuel line and its not tight. Don't how how to tight it...
Old Oct 23, 2010 | 05:44 PM
Anyone knows how to check the fuel system is working ok? I thinking also that its the octane of the gasoline here. I dont know how much is it but maybe isn't burning completely inside the engine.
Old Oct 24, 2010 | 03:16 PM
If I reset my car, taking of the battery and leaving the key on RUN for 15min. Will it help? I've heard that this helps to almost every imported car from the US to Bolivia because of the sea level, oxigen flow is not the same as in the states. Weather conditions are very different. Reseting my car will make adjust to fit my weather condition? So, this would stop pumping gas out of my exhaust and the snoring?
Old Oct 24, 2010 | 03:35 PM
05Slowline's Avatar
sounds like you have an intake side leak it says stage 3 so i assume your st3. check your gaskets and make sure all your bolts on the intake manifold are on right. intake leak will cause misfires etc etc. can't tell too well from the vid but thats what it sounds like to me.
Old Oct 24, 2010 | 03:54 PM
Intake is kinda dirty, I'm cleaning it right now with moist paper towel. I will put it on tight and make sure there are no leaks of air, when engine starts... Any other ideas?
Old Oct 24, 2010 | 04:32 PM
05Slowline's Avatar
no not the intake itself, the intake side of things, ie, s/c gasket, im to head gasket, im to head bolts not loose, etc etc.
Old Oct 24, 2010 | 05:11 PM
SeVeReDiStOrTiOn's Avatar
Are you sure it's not just condensation? Everyone's exhaust has water come out when cold until the cats light off.
Old Oct 24, 2010 | 05:20 PM
rukkee's Avatar
Yeah .... If that was raw gas i doubt it would make all the way back without getting burnt up or evaporating . You would have one hell of a fireball from time to time too.
Old Oct 24, 2010 | 06:52 PM
We are in summer here and would be it possible that condensation comes out so much? What about the snoring sound of the engine? its like it wants to turn off.
Old Oct 24, 2010 | 10:00 PM
rukkee's Avatar
I get water all the time ...summer , winter and anytime in between . I think humidity plays more of a part in it than temps do.
Old Oct 24, 2010 | 10:11 PM
what kinda snoring are we talking about? like grandparent snoring, or drunk dad?
Old Oct 25, 2010 | 01:41 AM
See the video on my first post.
Old Oct 25, 2010 | 01:52 AM
Whining-devil's Avatar
why is the tip soo close to the left side of the bumper
Old Oct 25, 2010 | 03:02 PM
The rubbers that hangs the muffler move with the vibration..I can't help it.
Old Oct 25, 2010 | 03:12 PM
elecblue06's Avatar
sounds to me like you have 60 lb injectors, get a tuner to look at your car and adjust it for the current area your in.. resetting the car by unhooking the battery might help.. i'm that is more then likely not gas
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
