Loose PCM
Old Jun 12, 2006 | 12:11 PM
Tomtwtwtw's Avatar
Loose PCM
A while back, I noticed my PCM (silver part in front of the fuse box with a heat sink and 3 wires plugged into it) was loose. Like it's sitting in that slot, but I can wiggle it or lift it out with no resistance at all. Last week at the track I noticed it was the same on another Cobalt. I'm wondering if this is normal or is there a clamp or two missing that should be holding it firm in place?
Old Jun 12, 2006 | 12:14 PM
MarcS's Avatar
The Stig
It's normal. You could use zip ties probably if you're worried about it, but It's not going to move.
Old Jun 12, 2006 | 12:17 PM
sscobalt06's Avatar
I noticed mine is the same too, I put that black hose that is above it down into the crack and that holds it steady.
Old Jun 12, 2006 | 12:36 PM
Tomtwtwtw's Avatar
I had that hose in there, but I wasn't sure if that could affect the hose or not, so I pulled it back out for now.
Solaris99
28
Mar 15, 2017 01:22 PM
TedSS
101
Apr 25, 2016 10:46 PM
Tupp
Sep 30, 2015 08:18 PM
jmelton327
Sep 26, 2015 10:04 PM
BettyBlue2.2
Sep 10, 2015 08:49 PM
