loosing boost in M62 @ WOT
i wasnt very clear on what i was trying to say. the end all be all solution would be to ditch the m62 if he wants to make power to 8k rpm. but if he went up in pulley size, the max power point of the powerband would move more towards redline and not drop off as badly near redline. it may make less power, but id be suprised if there was much of a loss. a 3 inch pulley would spin the m62 to 17000 rpm at 8 k rpm of engine speed
i believe it, but it made max power at 6800 rpm. stock cam 2.8" pulley cars do that. unfortunately, all of the efficiency and flow charts provide data to a blower speed of 14 k rpm. without real world testing, we cant know how the blower flows at 18 k rpm that hes spinning to.
youre right though, its not that bad
Ive known about your H65 for a while, very respectable for all GM parts, also my header compared to your GM honed mani might be the difference in boost drop off.
Overall I thought something was wrong as I thought the car was supposed to make more power at higher engine speeds especially with the Stg2 cams, but I am in essence past the M62's efficiency range, anyone know the guy who does the porting to the blower, I would be interested in getting mine done and seeing if it makes a difference with E50.
Like spawne said.... its the H62 that helps me out.
I still think he's a tad bit down on boost from where he should be, however. Someone had made a good point about the added efficiency of the cams, which would completely makes sense and is likely the culprit here. Stupid little m62.. lol
Yep. I saw 1 psi drop with my cams.
Great news! But will one of your ported blower be able to help me flow more cfms at the 7-8k RPM range? right now it seems my higher redline is not utilized as well as id like. already have heard good things about the ported blower from 09cobalt.
Amclure or something does them here.
Don't you do the ported blower casings? Or does MrBelvedere?
Last edited by blueLNFftw; Jan 27, 2015 at 05:48 PM. Reason: Automerged Doublepost
A ported m62 definitely isn't going to give big numbers by any means, but CobaltSS 16's setup yielded some good results with it, although I'm not sure who did his blower porting. Hopefully we can get back on the dyno soon to compare against his previous setup. We WERE supposed to do that this past Saturday, but of course, it snowed Friday into Saturday here so that got the big ol' fat axe.
^ Yeah Alex over at Granite State Dyno who did my pulls was bitching at me cause I didnt call before coming over on Saturday.
Alex: 'Well looks like we wont be able to do it today' he's looking at the car through the shop window... 5 mins later 'Well I guess since you drove all the way up here' as hes's pulling the car in... 5min later. 'You need to call me first so im not risking my equipment with a dyno pull' as he's strapping my car down! LOL
In my defense tried to get as much snow from the fender wells i could. haha
Alan (armcclure) ported my blower. I picked up 1-1.5 psi on my E85 2.7" setup in the upper RPM range until where I shift at ~7K rpm (i think my rev limiter is at 7.2k though.) Blower sounds money too lol
Definitely think it would be beneficial on Shanmans setup.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
