loosing coolant still
Old Sep 19, 2012 | 11:33 PM
Shogokuma's Avatar
ok, 2006 cobalt ss supercharge.
low coolant showing in the DIC, i have a brand new cilinder head, i dotn see a puddle, bad radiator cap?
im serioulsy lost.
Old Sep 19, 2012 | 11:35 PM
turbosmart4's Avatar
omg what a nightmare...
Old Sep 19, 2012 | 11:36 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Stupid question but did you ever do a coolant pressure test?
Old Sep 19, 2012 | 11:40 PM
Shogokuma's Avatar
not a stupid question, yes twice.
BUT, i think that test cannot test the cap as the cap IS the valve... because there is no radiator cap technically.. its the only thing left.. lol
Old Sep 19, 2012 | 11:51 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Oils clean? I have seen the oil coolers go bad but that usually makes the coolant bottle fill with oil
Old Sep 19, 2012 | 11:53 PM
Superbalt06's Avatar
heater core?
Old Sep 19, 2012 | 11:54 PM
Shogokuma's Avatar
my new cylinder head was installed by chevrolet, they changed the oil and everything i dont think its the head gasket anymore. i used to tthink it was
where would the heater core be located ill check it
Old Sep 20, 2012 | 08:01 AM
Take it back to gm and tell them its losing coolant
Old Sep 20, 2012 | 10:00 AM
bluebalt07's Avatar
^this. They worked on it so they should have put some sort of warranty on their work and if they didn't fix the problem, they should be responsible for it.
Old Sep 20, 2012 | 05:20 PM
Shogokuma's Avatar
the thing is that it was loosing coolant before..
im so exhausted this car has been nothing but nightmares and dealership trips and weeks with no car.
Old Sep 20, 2012 | 07:59 PM
bluebalt07's Avatar
Yes but they still should have a warranty on the cylinder head work which would include coolant leaks. So while they may not fix the problem if you take it back, they are required to at least check into and rule out it's not something they did.
Old Sep 20, 2012 | 08:16 PM
LamboW9's Avatar
^^this
its easy to overlook because it was done by a chevrolet dealer but everyone makes mistakes. if you were losing coolant before and your head went bad or if it was the head then how do you know it still isn't? they will pressure test and ensure its not something major. if its not the head then at least that rules out the most MAJOR problem of them all.
Solaris99
28
Mar 15, 2017 01:22 PM
brandon04
Oct 21, 2015 07:04 AM
Tupp
Sep 30, 2015 08:18 PM
jmelton327
Sep 26, 2015 10:04 PM
riceburner
Sep 26, 2015 12:57 AM
