Loud engine at idle
Old Nov 22, 2006 | 05:33 PM
3ds138's Avatar
Loud engine at idle
Hey guys.. got a question.. not to sure what it is..
I got a 2006 SS/SC has about 14000 kms on it
I just put my intake in couple days ago and i got a check engine light on, on my way home from work.
Also.. My car sounds really loud at IDLE? i pop the hood and it sounds really bad..
any ideas?
All i have is an intake.. but I also found it loud before the intake as well.. Could it be Lifters?? or something with the supercharger??
I know what my 1998 z24 sounded like with bad lifters.. but i can;t tell if its coming from the head or the supercharger..
any ideas.. let me know.. thanks
Old Nov 22, 2006 | 05:37 PM
chipsgt's Avatar
any ideas?
This might be a dumb question, and I dont mean to question your integrity with this, I am honestly curious... did you check to see if the filter is still on the end of the tube?
Old Nov 22, 2006 | 05:40 PM
Imlikedrpepper's Avatar
take it to the dealer, maybe an exhaust leak, or maybe something you cant really tell. Have someone look at it just to be safe.
Old Nov 22, 2006 | 06:01 PM
3ds138's Avatar
filter is still on
Old Nov 22, 2006 | 06:08 PM
D4u2s0t's Avatar
are you sure it's not just the way it sounds?? these cars are by no means quite at idle...
Old Nov 22, 2006 | 06:13 PM
3ds138's Avatar
i dono.. cause even in the driveway or when i pull up to an intersection the odd time.. the rpms.. seem to go nuts.. hope around and drop below and almost stall the car.. even somtimes when i reverse.. its weird.. and i can sometimes feel the car rumble when i am stoped at a light..
I don;t know if anyone else has this problem either.. but wheni turn off my car.. it shakes..
Old Nov 22, 2006 | 06:18 PM
Tomtwtwtw's Avatar
The real questions, is what kind of noise is it? Popping, rattling, grinding, scraping, knocking...describe the sound, and someone may be able to give you a better idea on what exactly is causing it.
Also, my car give a little shake when turning it off, too. That much is totally normal, especially if you have a torque brace and / or mounts.
Old Nov 22, 2006 | 06:27 PM
rally's Avatar
Did it start when you put the intake on?
You might want to check all your piping and make sure all your connections are tight. I know you have the S/c but when I added my cai to my 2.2 it was really loud, but it was supposed to be after that.
Old Nov 22, 2006 | 07:10 PM
D4u2s0t's Avatar
do you have any other mods?
Old Nov 22, 2006 | 07:14 PM
3ds138's Avatar
its a more rattling kind of noise
Old Nov 22, 2006 | 07:29 PM
D4u2s0t's Avatar
like something is loose? i would check your intake, make sure everything is tight... how long have you had it in? sometimes from the vibrations it comes a little loose after you install it, should always double check... make sure it's tight
biniecki
Oct 25, 2015 02:23 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
