Low boost after intercooler pump change
Old Jun 18, 2018 | 07:28 AM
Lazybodyworkguy's Avatar
hey guys I searched around but couldn’t find the exact same problem but here we go.....
I have an 06’ ss/sc no LSD.... when I bought the car the intercooler pump as out (no flow) but everything worked perfect boost in every gear, just a high temp I assume. No CELs at all.... so I bought the replacement pump changed it out lost a little fluid not much put more fluid in.... but now in 1st gear I don’t go over 0 psi of boost not matter how hard I accelerate. Second and third is usually strong boost but sometimes inconsistent ? The new pump is flowing properly and I hear whine. Not sure why with a broken pump I was able to reach full boost but now I can’t and or it’s not consistent ? Thanks !
Old Jun 18, 2018 | 07:53 AM
jdbaugh1's Avatar
Did you disconnect or touch anything else when you were changing out the pump? What are your IAT2 temps now with the new pump? Sounds like your boost bypass actuator is open and I would check and make sure the solenoid is functioning properly.
Old Jun 18, 2018 | 07:57 AM
I’m not aware or hitting or disturbing anything else ..... it is possible but I don’t believe so and my temp seems to be fine or no diff really, running K&N typhoon .... I manually can move the actuator rod and it seems to slide fine but at the top of its stroke it’s kind of “crunchy” and or makes a hard click ? Just weird like I said because before the pump swap everything worked fine
Old Jun 18, 2018 | 08:01 AM
jdbaugh1's Avatar
Only a few ways possible for you not to have boost. 1 is that your supercharger isn't spinning. If it is spinning only a closed off throttle body and/or the bypass valve can prevent it from building boost given it is a functioning supercharger.
Old Jun 19, 2018 | 06:34 AM
Could I still be low on heat exchanger coolant ? Or could there be air in it ? .... first sometimes very rare builds boost up to possibly 5 psi.... second gets boost and third and so on .... just frustrating because with a non functioning heat exchanger pump I had full 12 psi in every gear including first
Old Jun 19, 2018 | 08:05 AM
jdbaugh1's Avatar
You could very easily have an air bubble preventing the pump from circulating properly. In my experience the pump does not self prime very well and you have to ensure it is primed with fluid. However if your IAT2 temps are the same as before then that should not be the cause of your boost being pulled though it is an issue I would correct before worrying about boost.
The symptoms you describe are exactly what would happen if your boost bypass solenoid loses power or if your ECU is commanding it open. Get water flowing first, IAT2 temps down where they should be. Then check to see if your solenoid is functioning properly when energized (it will block manifold pressure and vent sc actuator line to atmosphere when energized. You can test this by manually energizing it and try to blow through) Then check to see if it is getting power when the car is running. If it isn't getting power it could be your ECU commanding it open. Do you have an illuminated CEL? There could also be a circuit problem preventing it from getting power but Im not familiar with how that is configured. There are other members on here with access to circuit diagrams that may be able to help with that.
Old Jun 19, 2018 | 10:19 AM
Thank you for the explanation, I’m not sure of my IAT temps.... and no I do not have any CELs
Old Jun 19, 2018 | 10:25 AM
jdbaugh1's Avatar
Do you know someone with an OBDII reader? You should be able to access IAT2 readings with one of those. I have a bluetooth unit I got off amazon that connects to my phone and lets you read live data. I think it was about $60. Worthwhile investment.
Old Jun 19, 2018 | 10:27 AM
I have a typhoon k&n so I could assume of hope I’m “cold” being in the splash guard in the fender but the sensor could be reading high just before I changed the pump I had no problem ....
Old Jun 19, 2018 | 10:35 AM
jdbaugh1's Avatar
IAT2 temps are post-supercharger. IAT1 temps are before. What you are looking for is if your IC pump is working correctly you will have much lower IAT2 temps than if it isn't. Are you sure the old unit wasn't working? How did you check it? If your IAT2 temps are high enough your ECU could pull boost but I honestly don't know how it is all mapped out and what all could trigger the ECU to do that.
I can tell you we aren't going to be able to figure it out for you without you doing some trouble-shooting. We don't know what you did to cause the boost to be pulled.
Old Jun 19, 2018 | 12:44 PM
Yea I checked the pump before I replaced it I could see coolant but no flow .... so I did what everyone told me to do, hit it with a wrench and it turned on I had flow ....I could see the swirl of the coolant but it only worked when it wanted to (turned off when it wanted to) had to hit it with a wrench again to turn it on..... now that I replaced the pump anytime the car is running and I open the cap I see the swirl flow right at the T....
Old Jun 19, 2018 | 01:09 PM
jdbaugh1's Avatar
Check your bypass solenoid as I described above if your pump is for sure working. Go from there.
slavik
Aug 11, 2019 05:25 PM
hunting1961
Jan 9, 2017 06:47 PM
o2k
Jul 12, 2015 01:17 PM
awilson
May 28, 2012 04:17 AM
ziggity
Apr 14, 2009 04:19 PM
