Low oil problem!!!!! Hellppp!!!!!!!
Old Apr 3, 2014 | 09:02 AM
Lucid Dreams94's Avatar
I just did mt oil change two days ago and for some strange reason my oil is low after putting 5 quarts in. I changed the drain plug and oil filter as well, and it is tight with no oil leaking around them at all.
So what else could i check to see why it is so low?
Old Apr 3, 2014 | 09:08 AM
05g5's Avatar
is it actually low? you pulled the dip stick and physically seen its low?
look for leaks..... look around the oil filter( my guess is you didnt install/correctly install that O ring ).. look around the vavle cover and anywhere els around the motor. you will find it, or at the very least smell it when the cars running.. ( burning it )
and uh, these cars dont throw the oil indicator untill you drive it with NO, none,zip oil in it... i lost my drain plug one day, i know. So dont drive it.. lol
if your having that much trouble you cant see where 5 qts went in 2 days, take it to a oil change shop. they got bays and can fully inspect under and over the car. they will find it.
Old Apr 3, 2014 | 09:16 AM
Thanks bro! I will do that. I checked all over the motor and there are no signs of leaking from the valve cover or the bottom of the head - i didn't see anything around the oil pan, oil filter or the drain plug so idk where it is coming from. And just this morning my check engine like came on too but there is no knocking or anything.
But i will take it to them and see what they can do for me. Thanks again bro!
Old Apr 3, 2014 | 09:20 AM
06cobaltncng's Avatar
is this a lsj? im pretty sure mine takes more oil than that.
Old Apr 3, 2014 | 09:21 AM
05g5's Avatar
It rattles like a basturd with no oil. You will hear it lol
Theres definatly no oil around the filter? You put the o ring in right and didnt break it???
You also never said you checked the dip stick? It is infact right out?
Really wierd if so..
The 2.2 takes 5 qts , the lsj iirc is just a toucj over. 6qts???
umrdyldo's Avatar
Think with your dipstick Jimmy.
SS/SC takes 6 quarts. My god I hope you haven't had this car long.
Old Apr 4, 2014 | 10:09 AM
I checked it all out and come to find out. My friend told me that it needs 6 to 6.5 quarts.....
I filled it up and its full. Drove it around and checked it the next day. Still the same so its all good.
Also the check engine light was my coolant temperature sensor. So i cleared the code and ima going to have it replaced this weekend.
I appreciate all the help and support from you guys!!! Thanks!!!
im having another issue with the car now. Check out my new post and see if anyone can help. Thanks.
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
roth
Sep 26, 2015 12:16 PM
