MAF codes
Old Jul 14, 2014 | 08:41 PM
c0de7477's Avatar
MAF codes
okay, so im sure somebody has had similar symptoms, but i just want to be sure and get some feedback with the codes i pulled.
p0102 - MAF sensor circuit low frequency
p0103 - MAF sensor high frequency
p0100 - MAF sensor circuit insufficient activity
car drives fine btw. Also, I've installed a ZZP intercooler kit and ottp stage 2 mounts and i never got the code before these.
could the intercooler be causing it? i haven't retuned yet.
Old Jul 14, 2014 | 08:45 PM
c0de7477's Avatar
ive also replaced the maf as well
Old Jul 14, 2014 | 11:23 PM
tomj77's Avatar
did u by any chance forget to plug the maf back in after u had to unplug it for mount install? if so unplug it and check to make sure no pins got bent. make sure its in right. disconnect battery for 10 minutes and try again.
Old Jul 15, 2014 | 05:29 PM
c0de7477's Avatar
the maf is fine
Old Jul 15, 2014 | 08:37 PM
tomj77's Avatar
how u know, if its fine it wouldn't throw codes lol
check for boost leak
Old Jul 16, 2014 | 12:58 PM
c0de7477's Avatar
I've replaced the MAF because that's what i suspected at first. I've checked for leaks. The car boosts fine. I'm curious if it's throwing codes because on the zzp lower charge pipe the map sensor is somewhat in a diff location.
Old Jul 16, 2014 | 01:34 PM
tomj77's Avatar
I doubt that. I don't think it matters where the map is on the pipe, it would still see same amount of pressure.
turbochargedss2012
Sep 20, 2023 12:17 PM
tomj77
Oct 4, 2015 11:39 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Extremespeed
Sep 29, 2015 04:34 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
