multiple problems with brakes
Old Mar 11, 2012 | 09:38 PM
nonee26's Avatar
2009 cobalt ss stock wheels and breaks
1. always squeal when I brake (I think rear brakes)
2. Sometimes when in reverse and breaking they let out a really really loud hornlike sound and no im not pushing my horn (Rear brakes)
3. Sometimes when Casual driving and i slightly turn my wheel to the left it sound like my front diver side brake is squealing, it continues to do it until i brake hard.
4. tonsss of brake dust
5. This may not be brakes but sometimes when im downshifting and braking, at around 15-0 mph my steering wheel turns aggressively to the left. I will even turn it back to the right and it will go right back to the left.
Please answer any or all of these please, or can anyone relate??
Old Mar 11, 2012 | 09:44 PM
Balt_and_Vette's Avatar
maybe a seized caliper? check your driver side calipers.
Old Mar 11, 2012 | 09:50 PM
nonee26's Avatar
it looked fine to me. O and another problem
6. my Ebrake doesnt hold up very well either. I took it to the dealership about a month ago and they tightened it and it was workin fine up until earlier today
Old Mar 11, 2012 | 09:51 PM
nikemax21's Avatar
1. CHeck your rear brake pads and rotors, 08-10 SS's have a problem from the factory of the rotors scarring and brake pads wearing unevenly (inside v. outside)
2. My rear brakes do the same thing in reverse, usually in the morning and I believe its just the pads cleaning off the moisture off the rotors.
3. Sounds like a warped rotor.
4. Stock pads produce a lot of brake dust. Its normal. Replace pads if youd like with some from R1 concepts
5. Sounds like a warped rotor dragging.
6. The ebrake sucks in these cars. You can tighten it if your like by removing the center peices by the ebrake and remove the ebrake cover and use a 10mm (i think) wrench to tighten it. Make sure you do not tighten too much or else your rear brakes will drag.
Id replace rotors and pads from R1. I had many of the same issues and I replaced the rotors and pads and I havent had any dragging or squeeling since. Only the usual reverse horn like symptom early in the morning.
Old Mar 11, 2012 | 10:03 PM
nonee26's Avatar
Thanks, all really helpfull. but My brakes are only really loud when in reverse if they are hot. It usually happens when im backing into a parking space after driving
Old Mar 11, 2012 | 10:29 PM
nikemax21's Avatar
Hmm thats weird. I wonder if the inside pad on one of ur rear brakes is worn very unevenly and causing such noise. Id take the rear wheels off and take a look behind the rotor.
Old Mar 12, 2012 | 01:19 PM
Chevrolet Cust Svc's Avatar
If you would like for me to follow up with your dealership on the emergency brake issue you mentioned, please let me know!
Sarah
GM Customer Service
Old Mar 13, 2012 | 06:43 AM
rogersj's Avatar
x2 for warped rotor and def change out the rear pads and rotors
Old Mar 13, 2012 | 07:10 AM
C_A_D88's Avatar
Most of the issues just sound like worn out pads, take um out an check um to see I they gotta be replaced
Old Mar 13, 2012 | 08:00 AM
Powell Race Parts's Avatar
yup gotta maintain ur ride.
Old Mar 15, 2012 | 12:05 AM
nonee26's Avatar
well i gotta appointment tom at the dealer lets see what they say.
Old Mar 15, 2012 | 09:11 AM
Looking forward to an update, noone26.
Sarah
GM Customer Service
Old Mar 15, 2012 | 05:48 PM
nonee26's Avatar
I also had a water leak somewhere in my trunk and it rusted up my jack and all. so i wont get my car back till tomorrow and they gave me a damn HHR
Old Mar 17, 2012 | 12:33 AM
nonee26's Avatar
k my water leek is fixed. said my brakes and rotors are still good and they couldnt find any problems with it. my Ebrake they ordered me a new parking brake rachet assembly. said it should be in tuesday. but they left me with almost no E brake until then
Old Mar 17, 2012 | 12:40 AM
kikal8's Avatar
id say definitely a seized caliper.. explains all of these things.
Old Mar 17, 2012 | 12:43 AM
nonee26's Avatar
well maybe it fixed itself when they took a look at it. ive only driven they car maybe 10 miles since i got it back but none of these problems have shown up yet.
Old Mar 17, 2012 | 11:28 AM
insylem's Avatar
  1. Possible pad worn down. Lots of styles of brakes have a squeeler that contacts the disk to make a squeeling noise when the pad is worn down
  2. Mine do that too depending on tempature and humidity.
  3. Not really sure about this one.
  4. Wow, 4, 000 lbs of brake dust on a car that weighs arround 3, 000 lbs? I get alot of brake dust too, I just wash it off ever so often.
  5. Differential brakeing. Check your passanger front side brake to see if its even working.
Old Mar 19, 2012 | 12:56 AM
nonee26's Avatar
my pads still have plenty of life on them, the rear brakes do look they are wearing more in the middle though. the dealer said they were fine though idk. problem 5 seems to be gone ever since my visit. problem 3 is still here but its not as loud now
Jan 12, 2016 12:01 AM
biniecki
Oct 25, 2015 02:23 PM
Sep 27, 2015 08:53 PM
