My car won't be driven for 3 months
I'm getting surgery and I will be unable to drive for a long time, maybe even longer than 3 months. How often should I start my car and how long should I keep it on?
Thanks
Thanks
Meh, I have a work van I drive 99% of the time, I start my car up at least twice a week and let it idle a good 5 mins at least before I go to work. Prob drive it 15 miles a week anymore haha.
I just had spine surgery on 12/6. I can't drive for another 2 weeks or so at least....
I parked my car at a friends that I trust and asked him to drive it at least once a week.
I think driving it is important, and better than just letting it run.
Take it or have someone take it around the block once and a while, being under a load is different then being at idle..
Plus i've heard just idling like that can cause condensation inside the motor but thats just hearsay yada yada so take that with a grain of salt
When I was deployed to Iraq for 3 months, I let my (then a 93 dodge shadow) sit in a parking lot. All I did was disconnect the battery. Came home, hooked up the battery, and it started right up and ran great for almost five years after that.
5 mins. of idling will produce more water vapor than will get burned off, so if u dont have a half hour to spend, better to not start it at all.
my car has been sitting in my moms garage in colorado springs since i left for deployment in june, she starts it 2 times a week and drives it around once a month, im looking to have surgery here soon also on my right shoulder(shifting arm!!!) on my AC joint i separated it...
pull battery (put on trickle charger), change oil, top fluids off, fill gas and park it. Do not start it. No need. that just gets condensation in the system. I put my tires on wood squares to keep them off the cement and fill them to 40psi. Idk why you guys start your cars, it makes no sense. GMPP engineer, bill, even recommended against it.
Turbo Johnny
Feb 21, 2019 09:41 AM
chris88z24
Sep 8, 2015 01:55 PM
