Need help with Diagnostic codes! How can I fix these?
Old Feb 13, 2009 | 07:41 PM
grahamSS33's Avatar
My airbag light is stuck on and I had it on a diagnostic computer deal, and it came back with these codes...B0022 and B0085. Anyone know what i need to do to fix these? I really dont want to go to the dealer. heres what the codes are:
B0085 LF/Driver Side Impact Sensor -SDM
B0022 Right Front Seat Belt Pretensioner Deployment Loop -SDM
I had the passenger seatbelt replaced and the bumper cover was replaced. The car was in a small accident.
Old Feb 13, 2009 | 07:44 PM
boostedss26's Avatar
does your seatbelt work or is it tight? and i'm guessing the side sensor needs to be replaced
Old Feb 13, 2009 | 08:38 PM
Coblasts's Avatar
Both those codes should of came up with a symptom code which is a two digit number behind the code
(00,01,02 etc) to help narrow down the actual problem with the circut.
Example B0085 02 which would be shorted to ground.
Old Feb 13, 2009 | 08:42 PM
PRND3L's Avatar
if it was in a sm accident, you need a new pretensioner and impact sensor, the pretensioner fired so its junk, it just depends on where the pretensioner is located, it may be in the buckle or in the belt.
Old Feb 13, 2009 | 09:54 PM
grahamSS33's Avatar
seatbelt works just fine since i replaced it. i bought the seat belt from the dealer, so the belt should be brand new. The passenger seatbelt did lock up, thats why i replaced it. How can i figure out what i need to replace?
Old Feb 13, 2009 | 09:57 PM
after you replaced it you know you need to get the codes cleared by the dealer right? you cant just replace the belt and wala it don;t work that way
every vehicle we do at work that the bags go off we put the bags , clock spring, seatbelt tensioners and sensors in and off to the dealer it go's to get cleared
Last edited by boostedss26; Feb 13, 2009 at 09:57 PM. Reason: Automerged Doublepost
Old Feb 13, 2009 | 10:32 PM
PRND3L's Avatar
airbag codes do, the run self check at the minimum every key cycle, i replace impact sensors and clocksprings alot, usually when you start the car the light goes out.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
