Need help with oil leak
Hello guys i need some help asap! I have a 06 Cobalt ss/sc and its pushing oil out of the oil fill cap. It also has a little blow by coming out of the cap, and I went to check the spark plugs to see if there was oil and 3 out of the 4 plugs were covered in oil... Does that mean my piston rings are bad? Another question i have is it is under warrenty and will a shorty header void that warrenty?
Unless you baught an extended warranty or one of those warranty plans, then you are not under warranty with an 06.
Do like the other guy said and check your crank case breather. You may need to replace your valve cover gasket rings around the spark plugs though.
importkiller
Sep 30, 2015 07:18 PM
