Need service instructions for Cabin blower
Old Oct 27, 2008 | 07:42 PM
Halfcent's Avatar
I'm old school
Mine has developed a rattle. I got underneath the passenger side dash to drop it out and try cleaning it, but couldn't find a single screw. Everything was plastic molded together. I didn't see any way to just remove the blower itself.
So, to all you GM Techs out there, could you please copy and paste the remove and replace instructions for the blower assembly. Thanks.
Old Oct 28, 2008 | 06:30 AM
denniss's Avatar
Here is the procedure. Sorry there are no pictures, I don't know how to post a web page and I can't insert a link because it is a secure sight. Actually, I think the instructions come with the new blower motor if it is from GM.
Dennis
Blower Motor Replacement
Removal Procedure
Disconnect the blower motor electrical connector.
Remove the lower blower motor cover heat stakes (1) with a small chisel.
Remove the lower blower motor cover.
Remove the blower motor nuts.
Important: Cut through the case as straight as possible because the motor cup must be reused. In order to prevent damage to the component, do not cut any deeper than necessary to remove the motor cup.
Remove the blower motor and cup from the lower case by cutting through the case between the circular ribs around the motor with a sharp utility knife.
Release the blower motor retaining tab and remove the motor from the cup.
Installation Procedure
Install the blower motor (1) into the motor cup (2) that was cut out of the lower case.
Notice: Refer to Fastener Notice in the Preface section.
Install the blower motor nuts (3).
Tighten
Tighten the nuts to 2.4 Nˇm (21 lb in).
Attach the service ring (4) to the motor cup (2) with the screws (5) included in the kit.
Tighten
Tighten the screws to 1.8 Nˇm (15 lb in).
Install the blower motor and service ring into the HVAC module using the screws (5) included in the kit. Make certain the blower motor electrical connector is pointing rearward in the vehicle.
Tighten
Install the lower blower motor cover.
Install the lower blower motor cover retaining screws.
Tighten
Connect the blower motor electrical connector.
Old Oct 28, 2008 | 11:06 AM
Halfcent's Avatar
I'm old school
You have got to be kidding me? I have to cut the case off of the car, and then reattach it with screws? Who the hell designed this system? Why would you not have the assembly put together with screws in the first place so as to make disassembly and servicing something you can do without having to cut plastic? So stupid. So now, I can't just take the thing apart to clean it because I would need the screws and "service ring" included with a new blower in order to put it all back together. Stupid.
Old Oct 28, 2008 | 12:16 PM
383_Stroker's Avatar
whoa.. i swear I posted... anyway..
PAIN IN THE BUTT to get the heater core and air box out of there.. so, if you can get it by cutting the motor out, by all means, go that route.
Old Oct 28, 2008 | 04:49 PM
Halfcent's Avatar
I'm old school
Who said anything about the heater core? I just want to service the blower, which is plainly accessible from the passenger side. But, as I have now learned, GM left no means of removing it without cutting it out. And that is just stupid.
Old Oct 28, 2008 | 07:16 PM
denniss's Avatar
Welcome to my world as a GM tech! All the manufactures do things that are really stupid from a service standpoint. After 17 years with Ford and 10 with GM, I can tell you that the blower motor is a relatively well designed! It really isn't as bad to install as it sounds, and once done it can be removed very easily.
Dennis
patooyee
Oct 15, 2015 05:11 PM
jimbofug007
Oct 2, 2015 12:06 PM
importkiller
Sep 30, 2015 07:18 PM
Extremespeed
Sep 29, 2015 04:34 AM
grampss
Sep 27, 2015 08:51 PM
